Flysky module users - You need to read this
16 Mar 2013 14:32 #7809 by PhracturedBlue
Flysky module users - You need to read this was created by PhracturedBlue
As of the nightly build eb9ea9f1006f (released just now) the flysky module will be disabled unless you update your tx.ini.
If you look at the current tx.ini you will see this:
[modules]
# enable-cyrf6936 = B12
# has_pa-cyrf6936 = 1
# enable-a7105 = A13
# has_pa-a7105 = 1
# enable-cc2500 = A14
# has_pa-cc2500 = 1
you must un-comment the 2 'a7105' lines to re-enable the flysky/hubsan protocols If you are using a flysky module without a poweramp (like the xl7105) then only uncomment the 1st line.
For users with a devo7e who haven't modified it, I recommend adding: has_pa-cyrf6936 = 0
There is no need to uncomment the 'enable-cyrf6936' line. for anyone. This is automactically enabled by the firmware.
You can tell if the protocol is enabled on the model page by looking to see if the protocol has an '*' in front of it. Those with an '*' are NOT enabled because the module is not properly configured.
16 Mar 2013 15:51 - 16 Mar 2013 16:11 #7817 by vlad_vy
Replied by vlad_vy on topic Flysky module users - You need to read this
After Tx setup and check tx.ini, I see that all lines enabled. Is it normal?
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = -0
has_pa-cc2500 = 0
Last edit: 16 Mar 2013 16:11 by vlad_vy.
16 Mar 2013 16:07 #7820 by PhracturedBlue
Replied by PhracturedBlue on topic Flysky module users - You need to read this
I don't see this. I see that I get 'None for a7105 and cc2500
did you uncomment the entire module section or just the a7105 lines?
16 Mar 2013 16:10 - 16 Mar 2013 16:18 #7821 by vlad_vy
I replace tx.ini without modification. Then setup Tx and check tx.ini. I meant that all # disappeared.
current_model=1
language=10
music_shutdown=0
mode=2
brightness=6
contrast=5
volume=9
vibration=0
batt_alarm=4300
batt_critical=3800
batt_warning_interval=10
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=-0
has_pa-a7105=0
enable-cc2500=-0
has_pa-cc2500=0
[calibrate1]
max=3691
min=448
zero=2112
[calibrate2]
max=3627
min=361
zero=1981
[calibrate3]
max=3649
min=476
zero=2028
[calibrate4]
max=3614
min=368
zero=2012
[touch]
xscale=187245
yscale=137625
xoffset=-379
yoffset=-17
[autodimmer]
timer=20000
dimvalue=1
[countdowntimersettings]
prealerttime=15000
prealertinterval=5000
timeupinterval=2000
[telemetry]
temp=celcius
length=meters
Last edit: 16 Mar 2013 16:18 by vlad_vy.
16 Mar 2013 16:42 #7827 by vlad_vy
Seems all OK. If I uncomment lines before replace tx.ini, # disappeared, but values changed to 0 for cc2500. If I replace tx.ini without uncomment lines for a7505, these lines also have values 0.
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=-0
has_pa-cc2500=0
[calibrate1]
16 Mar 2013 17:25 #7832 by PhracturedBlue
yeah it should have been a ';' instead of a '#' in the tx.ini.
I've also fixed it so wit will write 'None' for unused modules
10 Apr 2013 08:37 - 10 Apr 2013 09:35 #8822 by Felixrising
Replied by Felixrising on topic Flysky module users - You need to read this
Can this be documented in the manual or the Moduleinstallation.pdf?
Edit: Specifically if you happen to migrate your existing models along with your tx.ini then you lose this information and when looking for the solution it should be in the manual somewhere. I also find the power amp stuff a little confusing. Could you also elaborate regarding the "has_pa" bit, I'm got my 7105 from ali and neither the aliexpress nor ebay ones mention XL7105 or anything about a power amp.. how can we tell? Sorry if these are simple questions.
Last edit: 10 Apr 2013 09:35 by Felixrising. Reason: elaboration
10 Apr 2013 13:12 #8824 by PhracturedBlue
I updated the release notes which is where this info belongs.
If your module has a metal cage it has a power-amp. if it cost more than $5 it probably has a power amp. If it is advertised as '500m' or '1000m' it has a power-amp. If you know the link of the module you bought, I can tell you as well. If you still don't know, try enabling the power amp, and set the power to 1mW. If it still works at over 2 meters, you have a power-amp.
18 Apr 2013 21:49 #9043 by koonce0313
Replied by koonce0313 on topic Flysky module users - You need to read this
Hey Guys! I have updated to 3.0 and noticed my FlySky was disabled found this thread and did what instructions say to do. I rebooted my Devo10 and it comes up to a lit blank screen. Power Button does not shut the tx off. Pull battery is only way to power off. Thought I might have a bad install of 3.0 Tried again and same thing. I changed a7105 lines to =A13 and =1 Is there something I am missing. V2 worked great no problems. Any suggestions? Thanks in advance!
19 Apr 2013 03:58 #9045 by vlad_vy
I think something wrong with editing tx.ini file. Try fresh 'tx.ini' from archive, uncomment two lines for A7105 and replace 'tx.ini' in Tx. Then recalibrate and retune Tx.
19 Apr 2013 06:52 #9051 by dc59
I found this in "ModuleInstallation.pdf"
19 Apr 2013 11:10 #9052 by RandMental
Replied by RandMental on topic Flysky module users - You need to read this
Remember that also apply to the modelsxx.ini files. Use this open source editor:
notepad-plus-plus.org/download/v6.3.2.html
21 Apr 2013 01:08 #9085 by koonce0313
I followed evryone's advice and am still having no luck. I even went back to 2.0 and my V911 still will not work. I thought maybe one of the wires had come unsoldered. Checked that all all wires are firmly attached. I wonder if that board could have gone bad? I can bind my Genius CP (Devo rx) and eveything works fine v2 and v3. Any other ideas? How can I tell if that board has gone bad?
21 Apr 2013 01:52 #9086 by PhracturedBlue
If you are using 2.0 make sure to verify that the model is still setup properly. the 3.0 models are generally not compatible with 2.0. If it was working before, there is nothing in the 3.0 upgrade that would actually damage the module. Also, my experience is that they are fairly robust to mishandling.
21 Apr 2013 23:46 #9107 by koonce0313
I was able to get it working! When I upgraded to V3 I loaded my previous models that I had saved (which didn't work). I then re-downloaded the models again ( from website) and moved them over to the tx and all works. I didn't think it would make a difference but apparently it does. Thanks for all the replies and help guys! This is great software!!
04 May 2013 01:15 - 31 May 2013 22:10 #9521 by bigde
HI,..need help. I've upgrade my devo12s with a skyartec module from x3v tx701 hook up all the wires rights. I then upgrade to version 3.0... and I can't get the skyartec module to bind. I'm using pnote for editing to enable cc2500 A14 and change 0 to 1 and nothing workes. I've tried A13 but no luck I can't bind, the * is gone but can't bind. Any suggestion! :sick:
Last edit: 31 May 2013 22:10 by bigde.
24 Sep 2013 03:27 - 24 Sep 2013 03:28 #14025 by SLMcc
Hi Bigde. Did you get it working? I'm having similar trouble with the module from my V911 TX in a new to me 8s. If you got it working what did you have to do?
Last edit: 24 Sep 2013 03:28 by SLMcc. Reason: subscribe
Time to create page: 0.067 seconds
