Problems with DevoDfuSe_v1.41_Win7
- Primera06
I'm new here and I'm from Switzerland
I would like to shop on my Devo 8S Deviation 1.1.2
My problem is DevoDfuSe_v1.41_Win7 instaled and also updated the drivers but when I Run the program it finds the remote control I have not
It once had Works
Please someone can help me
I thank them in advance
greetings Raphael
- sbstnp
Start TX with Ext button depressed, should go intro programming mode.
Run DFuse as administrator, this might be it.
Devo 10 + 4in1
FrSky Taranis + TBS Crossfire
- Primera06
I have already tried everything but still does not work unfortunately
The computer recognizes the controller but does not indicate it in the program
- coaster
cheers
Graziano
- Primera06
The version 1.5.0 I have already tried it, unfortunately, not
The program is not easy to control
not really looking further
- sbstnp
Devo 10 + 4in1
- j35u5fr34k
- Primera06
The problem still exists
With my computer had ever works and not all at once more
no one can help me
Maybe you need run Device Manager from Control Panel as Administrator.
Device Manager->Right click on the STM device (should have a yellow exclamation mark next to it indicating it needs a driver to work)->Update driver->choose where to search for driver->Select the folder mentioned above, do not try selecting the x64 or x86 sub-folders as they will not work. You need to select the parent direct which has the .inf file. Click on OK. Several times it failed to install the driver but then worked when I unplugged the radio before clicking OK.
- Primera06
The program was no longer about 3 weeks ago is still the autonomous control and Jezt
The program DfuSe_Demo_V3.0.2_Setup assumes control but I need so that other programs
- marc
image.helipal.com/helipal-devo8-update-firmware-big-1.jpg
Especially follow the steps regarding the setup of the driver.
Also install the application to "Programme (x86)" and not to "Programme", and choose the driver for 32-bit (even if you should use 64-bit Windows).
I installed Dfu on several computers in thi manner, and it always worked.
Marc
- Primera06
I Thank you all for the help
- dado099
please use
DevoDfuSe_v1.41_Win7.exe
and specify to install to new directory
c:\Programx86
For me it worked !
- Primera06
I know nothing around Jezt also do what
- digitracer
Install everything on a second PC/Laptop.
If Deviation FW hasn't been installed already, have you checked/posted on the Walkera forum already?
- coaster
try to attach a Mobile Phone or something like that to test.
cheers
Graziano
I've seen such try before...
- Primera06
I was just at a colleague and had it on his computer when I made like him and went without problems
No I do not use the adapter UP02
- coaster
cheers
Graziano
- Primera06
Thanks for the demand.
Today I have the Windows 7 set up again the thought that any is incorrect because it is all gone at the beginning but unfortunately I have no luck, the control will not appear in the Program.
I do not know anymore what to do
- Problems with DevoDfuSe_v1.41_Win7
