- vmsda
Thks, DAT, today tried that too with the K110, no luck.dat wrote: Hi victzh
yes , i have try fine math -127 to +127 with coarse 0 from The fist i begin setup,
i add +5 math up untill +127 , and -5 down to -127 step by btep , many many cycle rounds
just like in forum many people post ,
but it all failed.
when i fell tired that way , ~suddenlly~ , a thought float in my brain ,
try coarse , give it a chance , And ~~ bingo done ...
- wasp09
victzh wrote: Judging by the code, Deviation Skyartec can bind in the first 6 minutes
If you can try it and verify that would be nice. We can reduce this to a more reasonable 1 minute or so.
I did not test stock S-FHSS TX - I did not have the original when I was implementing it. There is no word in the documentation about it.
Yes, verified that on my devo 10 with X303V. It can bind at around 5.5 minutes but not after 6.5 minutes. Those 6 minutes were so long that they felt like eternity...
I have no objections either way, cut it down or leave it as is.
- dat
sorry hear that, but don't giveup keep more trying , Good luck !
- Arnold
victzh wrote: @Arnold, F4 is exactly what refuses to work with it right now
You have all my encouragement
- vmsda
Further to my Post #56254, I managed to take better photos of the "bowels" of the 7E. Besides the thoughtful workmanship, one of them actually shows the soldering to the MCU in appreciable detail.victzh wrote: @vmsda,
your module is probably misconfigured or defective. To exclude the former you need to give us some info to decide upon.
Publish your hardware.ini file's contents here, and take a look at how the module installed - take photos of its soldering to the board.
No point in "trying" right now, nothing changed since your first try.
Looking forward to your feedback. Thanks again.
- HappyHarry
7105=?
2500=?
2401=?
- vmsda
HappyHarry wrote: what colour wires go to the three pins on the bottom right of the 4in1?
7105=?
2500=?
2401=?
7105 = black
2500 = brown
2401 = red
ADDENDA: in the meantime, I have had the opportunity to test an Hisky HCP100S and a Syma X9, and in both cases got a Bind on the first try, so the 2401 seems ok.
- victzh
This is how the board with mounted 4-in-1, bare board, and Devo 7E/AT9 adapter look like:
This is how adapter board is mounted in Devo 7E
Now with 4-in-1 module inserted
Adapter mounted in Radiolink AT9
4-in-1 in AT9
- mdmbc
- Arnold
victzh wrote: ... So far it works in Devo 10, Devo 7E and Radiolink AT9 (sort of, so far as Radiolink code works at all)...
What about 6S, 8S, 12S & F Series, please?
- vmsda
I am sorry not to have followed this topic at all. A simple question: in what way does this adapter complement the functionality afforded by the 4in1 RF module?victzh wrote: OK, promised photos of my adapter. So far it works in Devo 10, Devo 7E and Radiolink AT9 (sort of, so far as Radiolink code works at all)...
- victzh
@Arnold - 6S, 8S, 12S should just work, I can test on 12S myself, I don't have 6 and 8. F is more stubborn for some reason, and it's complicated by my inability so far to dump the bootloader - to debug it properly I need to erase MCU to unprotect it and thus need to dump bootloader first to restore it. I'm working on it, but it is still not there.
- victzh
- Arnold
]victzh wrote: ... 6S, 8S, 12S should just work ...
Great!
Have you decided if you will be offering just the board, or board populated with module, or maybe both ways? third party vendor?
- ursus69
Great!
+1
Looks great!!!
- victzh
Originally the plan was I will pass this to the maker of 4-in-1 module and he'll produce it as it is.
But for impatient I have several "motherboards" from previous versions - they're not too different from the final version (which is to be reworked by 4-in-1 module guy anyways to adapt to his process). I would sell them - board with logic, power supply SPI flash, and U.fl for antenna - I have 3 with antenna header on back side and several more with antenna header on the front side as on regular module. It doesn't have 4-in-1 module mounted, so some soldering is required. It's not that hard though. Also, 4-in-1 module has RF shield which tabs are outstanding on the back side. As my manufacturer can't do slots that small I omitted them at all - you need cut these 1mm tabs off with side cutters.
Also there is an adapter for 7E/AT9 - board with connector on it.
What would you pay for such board(s)? I'd be glad to recuperate some amount spent on development of all of this, at least materials.
And, unfortunately, I can't provide any guarantee - I try to make it work and so far it works on everything except F series - working on it - but as some assembly required it's not guaranteed.
- fredskidoo
7105=?
2500=?
2401=?
7105 = black
2500 = brown
2401 = red
My question is what solder points on the Devo 10 do these 3 wires go to? I have yet to find it explained in detail anywhere on this forum. I've had the 4in1 module from Banggood sitting here in front of me for 4 days searching for a concise guide to the install. All I find is that it plugs in with no soldering required...but it comes with three short black wires in it's static free baggy. Please advise and thanks to all . . . I love my deviated Devo 10!
Ethan
- Arnold
Vlad_vy posted comment #55157 in this thread. Take a look at the Devo10 picture.fredskidoo wrote: ... My question is what solder points on the Devo 10 do these 3 wires go to? ...
- fredskidoo
Thanks for your assist Arnold
Ethan
- dc59
It looks awesome!
- Devo 12s 3in1 / 4in1 RF module neat installation.
