GUI
27 Jul 2012 20:02 - 27 Jul 2012 20:02 #731 by PhracturedBlue
Replied by PhracturedBlue on topic Re: GUI
FDR wrote:
PhracturedBlue wrote:
We have lost the possibility to invert the source with using the push for selecting the icon...
yep. probably if you want the toggle to be inverted, you define a virtual channel and use that. the toggle supports using raw stick/switch input or the output channel, so it is flexible enough, if not particularly convenient. I suppose I could use a short-press to toggle and a long-press to enter the icon selector, but that would probably be confusing too.
...or make them dual controls, so in the usual way you can invert the value, and a plus button for the icon select... ;)
We're basically out of room unless we go to a 3rd page for the toggle controls.
Last edit: 27 Jul 2012 20:02 by PhracturedBlue.
27 Jul 2012 20:17 #732 by FDR
Replied by FDR on topic Re: GUI
PhracturedBlue wrote: We're basically out of room unless we go to a 3rd page for the toggle controls.
Yep. :)
27 Jul 2012 20:30 - 27 Jul 2012 20:30 #733 by PhracturedBlue
Yep. :)
Well, i found some room, so there ya go :)
Anything else you think we should do to the main-page/config? otherwise I'll probably start work on the model templates
Last edit: 27 Jul 2012 20:30 by PhracturedBlue.
27 Jul 2012 20:37 #734 by FDR
PhracturedBlue wrote: Well, i found some room, so there ya go :)
Cool.
I think it is enough for the prime time, so you may concentrate on other tings...
28 Jul 2012 05:41 #735 by PhracturedBlue
Well, I've now implemented the initial template code. If you select the model page, you can select 'Template' from the File spinbox.
From there you'll get a list of predefined templates.
So far I've only implemented the 4ch-simple and 4ch-dual-rates templates to make sure it works as expected.
Let me know what you think.
28 Jul 2012 08:13 #736 by FDR
Compile error:
+ Building 'emu_devo8.exe'
objs/emu_devo8-w32/model_page.o: In function `file_press_cb':
C:\MinGW\msys\1.0\home\FDR\src\deviation\src/pages/model_page.c:198: undefined r
eference to `MODELPage_Template'
collect2: ld returned 1 exit status
make: *** [emu_devo8.exe] Error 1
28 Jul 2012 12:37 #737 by PhracturedBlue
oops. Fixed
28 Jul 2012 20:03 #738 by FDR
Crash:
- Load an empty model;
- Click on the model image -> crash...
28 Jul 2012 20:27 #739 by FDR
Changed the tab order of the main page config's box and bar values.
28 Jul 2012 20:29 #740 by PhracturedBlue
FDR wrote: Crash:
fixed
29 Jul 2012 18:27 #741 by FDR
I'm back.
It seems that trim steps are not equal on the graph and in the calculated value.
I've set the step to 0.1, so it caused 1% throttle value change in every 10 clicks, however 10 clicks goes throw the half of the trim graphs on the main page.
29 Jul 2012 18:32 #742 by PhracturedBlue
FDR wrote: I'm back.
That is on purpose. the trim postion is -10 clicks to 10 clicks. So the max trim adjustment is 10 * trim-step
I'm open to other ideas on how it should work though.
29 Jul 2012 18:40 #743 by FDR
I think that won't be enough.
Remember the original has +-12% range, the older 2402 has +-100%.
In this way if I set the step to 0.1, I would have only +-1% range...
29 Jul 2012 18:48 #744 by PhracturedBlue
My concern is that there is no way to quickly zero out the trims. Maybe I can support +/-100 levels of granularity (rather than +/-10), and have a long-press on the trim be 10x a single press.
29 Jul 2012 19:07 #745 by PhracturedBlue
Okay. I did as I suggested. see if that helps.
29 Jul 2012 19:25 #746 by FDR
I like it!
29 Jul 2012 20:05 - 29 Jul 2012 20:05 #747 by PhracturedBlue
FDR wrote: I like it!
I'm basically done with my original todo list. So I'm definitely interested in any issues you see. Besides replacing the icons, the only thing I have left to do before releasing the emulator is to figure out how to save Tx settings on power-off.
I updated the emulator input/output display to be more intuitive. Note that the labels do not reflect the tx-mode (they are labeled for Mode-1). I don't know how to fix that, since I need to define the strings before I know the Tx mode, and can't change the strings once they are created.
Last edit: 29 Jul 2012 20:05 by PhracturedBlue.
29 Jul 2012 20:10 #748 by FDR
OK, I will take a look, but probably only tomorrow, because it is bedtime now and I had a tiring day...
I did some minor retouching on the main page config, for example renamed list items of the bars select to be consistent with the second page, etc...
30 Jul 2012 05:25 #749 by FDR
Compile error:
+ Compiling 'radio.c'
cc.exe: error: radio.c: No such file or directory
cc.exe: fatal error: no input files
compilation terminated.
make: *** [objs/emu_devo8-w32/radio.o] Error 1
30 Jul 2012 05:36 #750 by PhracturedBlue
I just committed the code to write the tx configuration. I moved the 'models' and 'media' dirs into a subdirectiory called 'filesystem'. I also renamed a few files. you may need to remove the 'obj' dir to get it to compile properly.
It should autosave the model and tx file when you quit normally (using '\')
Let me know if you see any issues.
