GUI
31 Jul 2012 19:33 #791 by PhracturedBlue
Replied by PhracturedBlue on topic Re: GUI
FDR wrote: The countdown timer is a bit weird: it immediately decease by 1, but at zero miss a second. Looks like some rounding error.
You can test it by showing both timers on the main page, and set them to start by throttle (Ch1 on the default).
After start it will show 0/9, 1/8, 2/7, etc seconds.
yep. that is because int(-0.9) == 0
and int(9.9) == 9
so if a countdown timer starts at 10, it will immediately switch to '9' (since it becomes 9.9) whereas a countup timer will switch to '1' 1 second later. This is how stopwatches work as well...
for the countdown timer, goingthrough 0,you see the same thing.
It goes 1.0 -> 0.9 -> ... -> 0.1 -> 0 -> -0.1 -> ... -> -0.9 -> -1.0
you will see values of 1, then 0 for 2 seconds then -1
It may be better if it showed -0 once the values went negative
31 Jul 2012 20:58 #792 by FDR
Replied by FDR on topic Re: GUI
Yep. That is what I thought...
I just wasn't sure if it is normal or not.
Tomorrow I will check the original, how does it do it.
P.S.: I've just got my Ladybird! :woohoo:
31 Jul 2012 21:13 #793 by PhracturedBlue
I did make the timer switch red as soon as it crosses zero (as opposed to at -1)
01 Aug 2012 05:29 #794 by FDR
I have reordered the model page, and separated some controls in groups on it...
01 Aug 2012 05:32 #795 by FDR
FDR wrote: Tomorrow I will check the original, how does it do it.
Well, the original fw is doing the same, except that there the two timers are not even in sync, and after the countdown has reached 0, they countinue with a + sign instead of -, to indicate the you are beyond that preset time...
01 Aug 2012 06:06 #796 by PhracturedBlue
Ok, I think what we've got is sufficient then. I'm going to bed now, but if you find anything else to change, just let me know. I have no other planned changes at this point before the alpha release at this time. I've merged your changes.
01 Aug 2012 14:27 #800 by FDR
Replied by FDR on topic Re: Countdown to release
I would like to modify the icons. I've already prepared them, but I only can do it at home in the evening.
I hope you will like them...
01 Aug 2012 18:22 #809 by FDR
Modified the header icons and their alignment...
01 Aug 2012 20:03 #815 by FDR
FDR wrote: Modified the header icons and their alignment...
So you don't like it... :(
01 Aug 2012 20:14 #816 by PhracturedBlue
huh? At work now. Haven't had a chance to look at it yet.
01 Aug 2012 20:42 #817 by PhracturedBlue
Ok, I pulled them, and they look good, so they are now merged. Thanks as always.
02 Aug 2012 05:41 #829 by FDR
I didn't dare to modify your plain ad heli picture, but there is some purpleish cast on the background. Is that intentional, or just a result of some bad color space conversion?
02 Aug 2012 05:55 #830 by PhracturedBlue
FDR wrote: I didn't dare to modify your plain ad heli picture, but there is some purpleish cast on the background. Is that intentional, or just a result of some bad color space conversion?
Neither. It is me being color-blind and not being able to tell. You can change the icons however you like, we just need to use free-to-distribute images. I got them here:
www.iconarchive.com/show/transport-for-v...helicopter-icon.html
but I don't really care about them as long as we can distribute them legally.
02 Aug 2012 14:53 #845 by PhracturedBlue
I'm planning to announce the 1st (emulator only) release tomorrow. Right now, I'm basically focusing on administrative stuff...getting binaries ready to go, updating the main website page, etc. I still need to swap out the 'toggle' icons, but any other gui related changes you want to make we should get done today if we want them in the release tomorrow.
02 Aug 2012 15:01 #846 by FDR
OK, I will change the plane and heli icon at home. (They are ready...)
02 Aug 2012 15:04 #847 by FDR
Oh yes, I wanted to adjust the main page widgets a bit, but that is not essential, probably I won't have enough time for it before release...
02 Aug 2012 18:05 #849 by FDR
FDR wrote: OK, I will change the plane and heli icon at home. (They are ready...)
Checked them in...
02 Aug 2012 18:08 #850 by PhracturedBlue
I made the single-tick exit as well as backslash. can you verify?
02 Aug 2012 18:36 #851 by FDR
PhracturedBlue wrote: I made the single-tick exit as well as backslash. can you verify?
What is a "single-tick"?
Backslash still doesn't work on a hungarian keyboard...
02 Aug 2012 19:13 #853 by FDR
FDR wrote: What is a "single-tick"?
Nevermind, I found it in the code...
So the ' doesn't work either...
On my computer the keyboard.exe shows \ and ' in the event_text, not in the event_key, which the code examines.
Time to create page: 0.119 seconds
