GUI
31 Aug 2012 02:53 #1296 by PhracturedBlue
Replied by PhracturedBlue on topic GUI
FDR wrote: A change request:
Could you make the model page to be the last (or we can say the -1. to the left), so it would be only one click away from the default (mixer) page.
I still think that the mixer page is the most used one, so it should be the first when we enter the model menu, but the second more important is the model page.
I would be like if the model page is the first, mixer is second, and then the rest, just we always start with the second page... ;)
Done. I also pulled your other changes.
31 Aug 2012 16:00 - 31 Aug 2012 16:01 #1301 by FDR
Replied by FDR on topic GUI
There are some strange new bugs.
In a source select box there are virtual channel up to Virt10, but on the mixer list there are 14, which behave weird: the 11. is a complex mixer, but if I want to set it back to None it hangs the program. Furthermore the None option is the first to left, not third after expo and simple.
The last 14. virtual has "Unknown" mixer type.
I know that they can be bad model data, but even then they shouldn't crash the program.
EDIT: ...that was in the emulator with the defaul model...
Last edit: 31 Aug 2012 16:01 by FDR.
31 Aug 2012 16:13 #1302 by FDR
On the mixer setup page in the mixer type select box the are Cyclic1-3, but they do nothing. What are they good for?
31 Aug 2012 16:18 #1304 by PhracturedBlue
FDR wrote: On the mixer setup page in the mixer type select box the are Cyclic1-3, but they do nothing. What are they good for?
They do something. They are basically predefined (non-editable) mixers, that use the swash type to mix the 1st 3 virtual channels. If you select a cyclic template, you will see the names of the virtual channels change accordingly.
31 Aug 2012 16:34 #1305 by PhracturedBlue
FDR wrote: There are some strange new bugs.
fixed
31 Aug 2012 16:38 #1306 by FDR
I cannot reproduce that virtual channel renaming...
BTW the binding button is visible when no protocol is set.
On the mixer list if I scroll down (no matter if one by one or with long press) and open and close a mixer, the scroll bar jumps up.
31 Aug 2012 17:11 - 31 Aug 2012 17:12 #1308 by PhracturedBlue
FDR wrote: I cannot reproduce that virtual channel renaming...
Select 'Cyclic1' for any of the 1st 8 channels. The 1st Virtual channel is now named 'CYC - AIL' on the mixer page. (It still shows u as 'Virt1' if you try to select it as a source manually though. I have to give that some thought)
Your other issues are fixed
Last edit: 31 Aug 2012 17:12 by PhracturedBlue.
31 Aug 2012 17:21 - 31 Aug 2012 17:24 #1309 by FDR
OK, I've got them...
(EDIT: BTW loading the CCPM template were not enough...)
How can one know, which cyclic he have to assign to the aileron, elevator and pitch?
Shouldn't we use the same name for the cyclic channels everywhere to ease to choose from them: CYC_AIL, CYC_ELE, CYC_COL or CYC_PITCH?
Last edit: 31 Aug 2012 17:24 by FDR.
31 Aug 2012 17:27 #1310 by PhracturedBlue
FDR wrote: OK, I've got them...
I didn't update the CCPM template yet.
Is there a 'standard' way to name the cyclic outputs?
The channels mix (for 120-degree swash)
cyc1 = collective - elevator
cyc2 = collective + elevator/2 + aileron
cyc3 = collective + elevator/2 - aileron
which of those is col, ail, ele?
31 Aug 2012 18:46 #1311 by FDR
Good question! :unsure:
01 Sep 2012 15:59 #1326 by PhracturedBlue
ok I did some testing with the devo firmware and found this:
cyc1 = ele
cyc2 = ail
cyc3 = pitch (channel 6)
I've updated the 6-channel template to have a reasonably realistic setting.
One note is that walkera seems to use a reversed ele (in front rather than in back?). such that the direction is opposite to the normal formula. so you need to set 'ele inversed' on the heli page. This isn't part of the 6ch template though.
I also increased the max default servo throw to 150%. this is the value that Walkera seems to use by default. I still need to go through all the protocols and make sure the >100% throws work for each one.
01 Sep 2012 16:25 #1327 by FDR
Yep, it looks much better now!
Now only the default model needs some tweaking... ;)
...and they use the ch7 for the gyro. How does it work with 6ch transmitters, I wonder?
01 Sep 2012 16:33 #1329 by PhracturedBlue
Should we support translating the template names?
It would make it easier for non-english speakers to use. The only downside is that we only have translations for officially supported templates.
01 Sep 2012 17:32 #1330 by FDR
Yes, we may support the default ones in the language files, the rest will be named by the users...
01 Sep 2012 20:15 #1333 by FDR
PhracturedBlue wrote: I also increased the max default servo throw to 150%. this is the value that Walkera seems to use by default.
No, they use 100% as default, and I think it is the right think to do.
It's only an option to increase it to 150%...
01 Sep 2012 21:24 - 01 Sep 2012 21:29 #1334 by PhracturedBlue
Not from what I see. Theyuse 100% as the range multiplier. They seem to set a hard-limit on throw at 150% (maybe this can also be adjusted upwards I dunno)
For instance, with all values at 100% and trim maex, the max value is > 100%.
Also, with 120-degree CCPM, and all values at 100% the max value is 150%. You can measure this on the servos or by looking at the monitor page.
I don't think Walkera has any concept of a real servo limit that is user controlabale
Last edit: 01 Sep 2012 21:29 by PhracturedBlue.
02 Sep 2012 17:15 #1339 by FDR
PhracturedBlue wrote: Not from what I see. Theyuse 100% as the range multiplier. They seem to set a hard-limit on throw at 150% (maybe this can also be adjusted upwards I dunno)
Internally I don't know, but on the UI they have 100% default servo adjust, which can be extended to 150%.
May be they normalize after some stages, or may be the 100% here is not the same value as 100% there...
PhracturedBlue wrote: I don't think Walkera has any concept of a real servo limit that is user controlabale
No they have only scaling, but they have two values for the negative and positive halves.
02 Sep 2012 18:14 - 02 Sep 2012 18:16 #1340 by PhracturedBlue
Right. In the Devo firmware, 'Servo Adjust' is the same as my 'scale' value on the channel page in Deviation (except that they allow separate settings for positive and negative). Deviation defaults to 100% just like the Walkera firmware.
They also have a hard-limit at 150% which does not seem to be adjustable.
My 'max' and 'min' values allow adjusting the hard-limit to prevent servo/model damage. They are currently set at 150% just like the Walkera firmware.
Note that the 'limits' don't work when the Rx is doing its own mixing of course since the Tx has no knowledge of it
Last edit: 02 Sep 2012 18:16 by PhracturedBlue.
02 Sep 2012 19:42 - 02 Sep 2012 20:04 #1341 by FDR
We need some more usable toggle images...
Here is my first try, but will try to find some better... ;)
EDIT: bmp was not on the allowed list... :oops:
There should be an image of gears to warn they are out!
Last edit: 02 Sep 2012 20:04 by FDR.
02 Sep 2012 19:57 #1342 by PhracturedBlue
FDR wrote: We need some more usable toggle images...
Here where?
I don't see them on the forum or in your repo.
Time to create page: 0.791 seconds
