GUI
02 Sep 2012 20:07 #1344 by FDR
Replied by FDR on topic GUI
Sorry, it was a file type restriction...
It's not that good to put into the repo yet.
I have to find some better images...
It's just the concept, that we need some warnings, holds, etc...
03 Sep 2012 02:45 - 03 Sep 2012 02:49 #1345 by PhracturedBlue
Replied by PhracturedBlue on topic GUI
What do you think of these icons initially?
Note: You can make toggle.bmp as wide as you want (in multiples of 32) it justr must be 31pixels high.
Last edit: 03 Sep 2012 02:49 by PhracturedBlue.
03 Sep 2012 04:45 #1346 by FDR
Oh, I must have forgotten about that!
Yep, it is nice, I just need one for the throttle hold, That is the only one I use them for...
03 Sep 2012 13:40 - 03 Sep 2012 13:41 #1349 by PhracturedBlue
Here it is with throttle hold
Last edit: 03 Sep 2012 13:41 by PhracturedBlue.
06 Sep 2012 01:20 #1370 by PhracturedBlue
I updated the code to allow templates to be named *.ini (as long as it is still in 8.3 format). Note that the one thing you lose with this change is that it is now impossible to get consistent ordering of the templates on the page. there is no easy way to sort them, s they will show up in the order they exist in the filesystem (random)
06 Sep 2012 04:27 #1373 by FDR
Yep, I was expecting that, but not a big deal IMO.
Just like the languages...
06 Sep 2012 08:11 #1374 by FDR
One more possible feature request:
Would you make it possible to select a picture for the model icon.
It could be like the model select (file names in the list, actual picture shown on the left), but it should only show the image files of proper size...
07 Sep 2012 03:22 #1380 by PhracturedBlue
FDR wrote: One more possible feature request:
Done. But it will show all icons in the 'modelico' dir. If you put a wrong-size icon in there, it will not work properly.
07 Sep 2012 04:58 #1383 by FDR
I've made the "Icon" button translatable, and put the label into lang.hu.
Pushed...
07 Sep 2012 14:39 #1387 by PhracturedBlue
I just checked in support for virtual channels since it was really easy to do.
Basically, you can set the trim output to be a channel rather than an input, and it will directly modify the channel output.
You can use any button for this (so left/right and up/down also work). Using ENT/EXT would probably be a bad idea though.
If you choose a button that is used elsewhere (like up/down or left/right) they will only work in virtual channel mode from the main page.
07 Sep 2012 14:54 #1388 by FDR
Cool!
I'll try...
10 Sep 2012 07:35 - 10 Sep 2012 07:35 #1459 by wuselfuzz
Replied by wuselfuzz on topic GUI
FDR wrote: I changed two pages to make some room for the translated labels, but it didn't solved the room need of "Hintergrundbeleuchtung". ;)
Pushed...
Duh. I checked out the translations in context last weekend. Replace "Hintergrundbeleuchtung" with "Helligkeit" (Brightness).
I hope to find time to look through the rest this evening and submit some fixes.
Last edit: 10 Sep 2012 07:35 by wuselfuzz.
11 Sep 2012 18:30 #1534 by FDR
I would like to change the order of controls on the channel page to help it understand better. I thought it would be better to show the settings in the order they are applied, and separate the failsafe from the others with some space to sign that it is something different.
My question is: what is the final order of these?
safety -> subtrim -> scale -> min/max limit -> reverse ?
11 Sep 2012 18:47 - 11 Sep 2012 18:50 #1537 by FDR
:blink:
Oops. I've just seen that you rearranged that page, I suppose to gain some space to the translated labels.
I have to say, that I liked the previous look more...
Anyway, I still think, that we should order them to match the order they are applied. It would help to understand they meaning and use...
EDIT: if this one column arrangement stays, we should use some more obvious label in that larger space...
Last edit: 11 Sep 2012 18:50 by FDR.
11 Sep 2012 19:37 #1541 by PhracturedBlue
FDR wrote: :blink:
Me too, but this is a lot more flexible. The Russian translation is particularly long and needs the additional space
Sure.
The order is trim -> subtrim -> scale -> reverse ->safety ->max/min
But that order really doesn't look right. I think it should probably be:
Trim -> safety -> subtrim -> scale -> reverse -> min/max
or possibly
Trim -> safety -> scale -> subtrim -> reverse -> min/max
Note that 'Trim' doesn't appear on this page, however I added it for completeness.
sure
11 Sep 2012 20:16 #1545 by FDR
Why the min/max is after the reverse? This way an assymetrical min/max values should be switched if one set the reverse after...
11 Sep 2012 20:19 #1546 by FDR
BTW I have some minor tweak request too:
The toggle bitmap selection should have cancel, if I don't want to change, just take a look. Especially, that it isn't indicated, which is the actually selected one...
11 Sep 2012 20:30 #1547 by PhracturedBlue
FDR wrote: BTW I have some minor tweak request too:
bitbucket.org/PhracturedBlue/deviation/issues/new
Because I didn't think it through very well. You are right that makes more sense.
12 Sep 2012 08:42 #1556 by FDR
If I think about it more, may be it is still better to have the min/max last...
While ordering them as they are applied will help to understand, it is not necessarily the order they will be set.
Probably everybody starts a setup with setting the reverses. Subtrims (i.e. centering a servo) and especially limiting the servo throw to be safe will be the last steps...
12 Sep 2012 18:42 #1565 by FDR
PhracturedBlue wrote: I think it should probably be:
or possibly
If the subtrim is used strictly for centering the servo arm, then it should be after the scaling...
Time to create page: 0.142 seconds
