deviation-devo12-NEW Widescreen build
04 Feb 2013 18:56 - 18 Mar 2013 15:50 #6017 by Hexperience
deviation-devo12-NEW Widescreen build was created by Hexperience
--- See next post --- Below is the widescreen build ---
Read through the threads for the Devo12:
www.deviationtx.com/forum/builds/1380-de...89f1f-devo12-support
www.deviationtx.com/forum/7-development/893-devo-12
As always this is an experimental build, proceed at your own risk, warning, turn back now, this means you. :angry:
Having said all that, it's looking good on my 12s! :lol:
Last edit: 18 Mar 2013 15:50 by Hexperience.
09 Mar 2013 23:10 - 18 Mar 2013 15:53 #7568 by Hexperience
Replied by Hexperience on topic deviation-devo12-ef487c8
New Devo12 experimental build!
This is completely off the radar as far as on going bug fixes. This is the version that RBE2012 and I have worked on. RBE did all the serious work, I just moved the objects around on the pages.
Same warnings apply as above. Working well on my Devo12.
Also adding a zip of the emulator WITH the file system. You may also need more dll's to run it, vlad_vy has posted them below. Thanks vlad_vy!
Last edit: 18 Mar 2013 15:53 by Hexperience.
10 Mar 2013 15:43 #7611 by Ustas69
Replied by Ustas69 on topic deviation-devo12-ef487c8
Emulator not works, error: libgcc_s_dw2-1.dll not found.
10 Mar 2013 16:55 #7616 by Hexperience
Hmm. I just redid the emulator zip file. I had not put the filesystem in the correct folder.
That shouldn't have anything to do with the libgcc error though.
I don't see the libgcc dll in any of the other emu builds. Not sure if it's only needed for the devo 12 emu for some reason...
Can anyone else chime in here to lend a hand?
11 Mar 2013 03:23 #7629 by Ustas69
At other comp under Win7 32bit is same error.
11 Mar 2013 04:01 #7631 by vlad_vy
Replied by vlad_vy on topic deviation-devo12-NEW Widescreen build
You need these dll:
File Attachment:
File Name: emu_devo12_libs.zip
File Size:444 KB
11 Mar 2013 05:16 #7632 by thloh85
Replied by thloh85 on topic deviation-devo12-NEW Widescreen build
Thx Hexperience and RBE2012, and everyone who made this happen. Going to test it on my Devo12 when I get home today!!! HOORAY!!!
11 Mar 2013 05:56 #7633 by Ustas69
Replied by Ustas69 on topic deviation-devo12-NEW Widescreen build
vlad_vy wrote: You need these dll:
Thank you, Vlad, working good.
12 Mar 2013 05:19 #7652 by thloh85
Working great so far. No crashes, no random reboot so far, and I'm very happy with the wide screen!!!
Thanks a lot again!!!
15 Mar 2013 00:52 #7765 by flythk
Replied by flythk on topic deviation-devo12-NEW Widescreen build
Installed this build on my new 12S without any issues. This is really turning it into the best radio out there!!
One thing I noticed is that I can't change the language back to english after selecting another language. English is not on the list of language options. I can probably reinstall to get around this, but I thought I'd mention it.
Thanks for the great work!
  • rbe2012
  • rbe2012's Avatar
15 Mar 2013 06:06 #7773 by rbe2012
Replied by rbe2012 on topic deviation-devo12-NEW Widescreen build
Maybe a silly question but...have you seen the scroll bar? You have to touch the upper arrow to see "English" again (tested after setting the language to "German").
17 Mar 2013 21:10 #7878 by flythk
Well, that is embarrassing - my touchscreen wasn't calibrated, so I couldn't hit the "up" arrow on the scroll bar. After calibrating I am back to English with no problem.
20 Apr 2013 04:57 #9066 by DemonOfPyro
Replied by DemonOfPyro on topic deviation-devo12-NEW Widescreen build
Any issues found with this build yet? I'm eager to try it, just don't wanna be the guinea pig with a 700 size heli.
  • rbe2012
  • rbe2012's Avatar
20 Apr 2013 05:49 - 20 Apr 2013 05:50 #9067 by rbe2012
I didn't have too much time to work on this. I advise NOT to use it for flying (maybe with a little bird what will do no harm).
While developing I had some crashes (in the emulator, I don't have a Devo12) and I have to take a intensive deep look in the memory management of the code (esp. using strings longer than defined).
So please be careful when using although I had no crashes in the last time...
EDIT: When my development is for the gui the crashes can happen when the main page is displayed too (what will be usual when flying).
Last edit: 20 Apr 2013 05:50 by rbe2012.
20 Apr 2013 05:53 #9069 by DemonOfPyro
alrighty, thanks for the heads up.
20 Apr 2013 10:41 - 20 Apr 2013 10:56 #9074 by Hexperience
Replied by Hexperience on topic deviation-devo12-NEW Widescreen build
I have been using this build since i posted it. I had one reboot when the radio sat untouched for a long time. I had the same reboot happen once on my devo8.
Since then i always make sure not to set the screen dimming to off.
Id say i have about 30 flights on this build up to a 500 size heli.
There is always a risk... Even if you are using stock firmware. But for a 700... I would not tell you its perfectly safe.
The build posted here is one of the early builds with wide screen support. So it has less differences from the true deviation code at that time. Since then rbe2012 has done more changes but this build doesnt have those changes.
The other thing to consider is the protocal you are using. Devo protocol for example is very stable in deviation where as dsm might not be as stable. Im just reffering to the fact that dsm dosent like to bind if its set at less than 7 or 8 channels and that they are still working on telemetry support. Im not saying dsm is unsafe just that the protocol and rx should be taken in to conaideration when thinking about using custom firmware at all... This build or any other
Last edit: 20 Apr 2013 10:56 by Hexperience.
Time to create page: 0.044 seconds
