4.0.1 for 7e with 2 2way patch (updated 4/1/14)
- HappyHarry
02 Jan 2014 15:12 - 04 Jan 2014 14:59 #17738
by HappyHarry
4.0.1 for 7e with 2 2way patch (updated 4/1/14) was created by HappyHarry
here is my deviation 4.0.1 build for the 7e including the 2x2way switch patch, i have also disabled telemetry and enabled the main screen layout editor
Last edit: 04 Jan 2014 14:59 by HappyHarry. Reason: update to 4.0.1
02 Jan 2014 16:19 #17743
Replied by rbe2012 on topic 4.0 for 7e with 2 2way patch and extra toggle icon
Harry,
you should put additional toggle icons in toggle3.bmp - this is where user toggles should be kept in.
Since you offer a patched version I don't think that it is really wrong to change the toggle[0|1|2].bmp too, but it is not the way which was intended.
BTW: great that you offer the patched version. This frees my time...
- RandMental
02 Jan 2014 17:05 #17750
by RandMental
Replied by RandMental on topic 4.0 for 7e with 2 2way patch and extra toggle icon
Please generate patch files for us, so we can apply these changes to new versions as it come along.
- HappyHarry
02 Jan 2014 17:26 #17752
by HappyHarry
Replied by HappyHarry on topic 4.0 for 7e with 2 2way patch and extra toggle icon
i only needed to modify the one 3way patch to make it work, the two 2way original patch works fine. but tbh i don't understand why the original 3way patch failed as the actual code changes in the original patch are the same in my modified patch?
anyway i have attached the two 2way patch to the first post
- dianjing
02 Jan 2014 21:55 #17782
by dianjing
Replied by dianjing on topic 4.0 for 7e with 2 2way patch and extra toggle icon
can you help me to make a new firmware for 7e with 2 3way patch.
thank you !!!
thank you !!!
- mpicpu
03 Jan 2014 17:42 - 03 Jan 2014 17:44 #17870
by mpicpu
Replied by mpicpu on topic 4.0 for 7e with 2 2way patch and extra toggle icon
What do I need to do to apply these updates, what do I do with the Two2way...TXT file? Where does it go?
Last edit: 03 Jan 2014 17:44 by mpicpu.
- HappyHarry
03 Jan 2014 18:03 #17876
by HappyHarry
the txt file is a linux patch file (it only has a .txt ending to make the forum accept it, as it wont accept .patch files as attachments) and is only used if you are building the firmware yourself. if you don't want to or can't build the firmware you yourself just download the zip and install it in the usual method
- HappyHarry
04 Jan 2014 15:01 #17920
by HappyHarry
Replied by HappyHarry on topic 4.0.1 for 7e with 2 2way patch (updated 4/1/14)
i've updated the build to 4.0.1 also included the full patch to enable target defs changes, both are in the op
Time to create page: 0.034 seconds
Builds
- 4.0.1 for 7e with 2 2way patch (updated 4/1/14)
