Deviation v5.0.0 build with latest protocols
23 Aug 2019 04:47 - 26 Aug 2019 04:16 #74967 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Protocol e010 cc2500, from goebish
Add a new protocol for Eachine E010 using the CC2500 instead of NRF24L01
* Add frequency tuning to WFLY protocol, from goebish
Add frequency tuning option to WFLY protocol
* Read multiplexed PID values from telemetry data
For SilverWare, optional telemetry support was added to the Bayang protocol quite some time ago.
Recently, current PID settings were added to the telemetry data. This pull request makes them available via FadesA, FadesB, and FadesR. The change is backwards compatible and has no implications for older firmware which does not send these values.
The PID values are sent sequentially using just two bytes.
Details: https://www.rcgroups.com/forums/showpost.php?p=42032515&postcount=398
* Enable optimized dfu for all devo targets
* Add V761 protocol, from goebish
Protocol for Volantex V761-1 Trainstar Mini fixed wing
also works with Volantex Ranger 600 762-1
Channel 5: gyro on/off
Only 3 transmitter IDs/channels, selected with Fixed ID % 3.
https://www.deviationtx.com/forum/protocol-development/7798-volantex-v761-1-firestar-mini-protocol
* Add support for Flysky AC type telemetry, from hexfet
Adds additional sensor support
(23.08.2019)
Files deleted, see below...
Last edit: 26 Aug 2019 04:16 by vlad_vy.
23 Aug 2019 04:53 - 26 Aug 2019 04:17 #74968 by vlad_vy
I can't attach more than 10 files, and so XMS builds attached with separate message
(23.08.2019)
Last edit: 26 Aug 2019 04:17 by vlad_vy.
23 Aug 2019 04:55 - 26 Aug 2019 04:17 #74969 by vlad_vy
Fresh emulator builds
(23.08.2019)
23 Aug 2019 05:29 #74970 by Birdman
Replied by Birdman on topic Deviation v5.0.0 build with latest protocols
was E012 ever sorted?
  • Kentuckian
  • Kentuckian's Avatar
  • Home is Bullitt County, Ky
26 Aug 2019 02:56 #74997 by Kentuckian
Replied by Kentuckian on topic Deviation v5.0.0 build with latest protocols
What please is a "Fresh emulator build" and how do learn to use it?? Thanks.
Live in FailSafe mode
26 Aug 2019 04:15 #74999 by vlad_vy
It's transmitter emulator for Windows. See last article of User Guide how to use it.
26 Aug 2019 04:20 - 28 Sep 2019 12:32 #75000 by vlad_vy
* Fix "BUTTON_HAD_LONGPRESS"
* Add Telemetry reset, from hexfet
Add feature to reset telemetry values on long press of Up button on telemetry monitor page.
For Frsky telemetry this resets the vario altitude "ground level" to the next received telemetry value, which zeroes the vario altitude telemetry value. Also resets the battery discharge accumulator to zero, and minimum cell voltage. The ground level value is saved in the model file to save the setting through power cycles - the value is fairly constant during a single day of flying in stable air.
(26.08.2019)
Last edit: 28 Sep 2019 12:32 by vlad_vy.
26 Aug 2019 04:23 - 28 Sep 2019 12:33 #75001 by vlad_vy
(26.08.2019)
Last edit: 28 Sep 2019 12:33 by vlad_vy.
26 Aug 2019 04:25 #75002 by vlad_vy
Transmitter emulator
(26.08.2019)
File Attachment:
File Name: deviation-...8-26.zip
File Size:936 KB
File Attachment:
File Size:657 KB
File Attachment:
File Size:709 KB
File Attachment:
File Size:934 KB
File Attachment:
File Size:1,146 KB
File Attachment:
File Size:934 KB
File Attachment:
File Size:1,160 KB
File Attachment:
File Size:933 KB
File Attachment:
File Size:1,147 KB
File Attachment:
File Size:882 KB
26 Aug 2019 04:30 #75003 by Birdman
Birdman wrote: was E012 ever sorted?
I guess not.
26 Aug 2019 04:44 #75005 by vlad_vy
I don't know. If E012 doesn't work with nightly builds, it will not work with v5.0.0 build. I use protocol updates from nightly builds.
28 Sep 2019 12:43 - 29 Oct 2019 05:59 #75159 by vlad_vy
* Fix missed "BUTTON_REPEAT" flag
* Convert mixer beep_lock variable to flag
* Don't run video_getstandard in every event loop, from howard0su
Only check video standard after we change the video_enable. In case of no signal, we will keep checking every 1 second.
(28.09.2019)
Last edit: 29 Oct 2019 05:59 by vlad_vy.
28 Sep 2019 12:45 - 29 Oct 2019 05:59 #75160 by vlad_vy
(28.09.2019)
29 Oct 2019 06:02 #75331 by vlad_vy
* Change SPI2 speed from 2.25MHz to 4.5MHz
* Fix A7105 hanging
(29.10.2019)
File Attachment:
File Name: deviation-...0-29.zip
File Size:671 KB
File Attachment:
File Size:670 KB
File Attachment:
File Size:671 KB
File Attachment:
File Size:886 KB
File Attachment:
File Size:669 KB
File Attachment:
File Size:672 KB
File Attachment:
File Size:885 KB
File Attachment:
File Size:669 KB
File Attachment:
File Size:876 KB
File Attachment:
File Size:1,421 KB
29 Oct 2019 06:03 #75332 by vlad_vy
(29.10.2019)
File Attachment:
File Size:434 KB
File Attachment:
File Size:1,196 KB
File Attachment:
File Size:904 KB
File Attachment:
File Size:1,197 KB
29 Oct 2019 16:35 #75335 by OrbitalGolem
Replied by OrbitalGolem on topic Deviation v5.0.0 build with latest protocols
Hi Vlad - many thanks for your support, it's appreciated. I'm running one of your builds from April/May of this year and fly Spektrum only. Do any of the recent builds contain changes that would improve Spektrum support? Trying to determine if I should upgrade.
29 Oct 2019 16:40 #75336 by jitter
hi, thanks for your work! also got some questions:
- voice support is only available in the nightly builds, right? seems to be bit buggy for me - sometimes the voice are looping for some time.. which gets annoying.
- would you suggest in trying your builds over the nightly ones? the voice suppport is the only reason for me for now.
- is the model data compatible - can i "downgrade" without having to reset them all?
best regards
30 Oct 2019 00:26 #75339 by joeclone
Replied by joeclone on topic Deviation v5.0.0 build with latest protocols
OrbitalGolem wrote: Hi Vlad - many thanks for your support, it's appreciated. I'm running one of your builds from April/May of this year and fly Spektrum only. Do any of the recent builds contain changes that would improve Spektrum support? Trying to determine if I should upgrade.
Hey Orbital, what tx do u use? I've had trouble with spektrum sats not binding on my devo10 using this and the nightly versions of the firmware.
Do you've cc2500 active in your hardware.h file?
30 Oct 2019 00:48 - 30 Oct 2019 00:49 #75340 by OrbitalGolem
Devo 8 and Devo 8s. No binding issues with the build from 3/5/2019, across Spektrum, Lemon, and Orange receivers. No idea what you mean by cc2500. Default settings.
Last edit: 30 Oct 2019 00:49 by OrbitalGolem.
30 Oct 2019 02:07 #75341 by joeclone
So you've no additional modules installed?
Time to create page: 0.086 seconds
