Reference nightly build Deviation v5.x.x
15 Aug 2019 06:43 - 22 Aug 2019 07:43 #74890 by vlad_vy
Reference nightly build Deviation v5.x.x with latest protocols. Based on "8 Nov 2018" nightly build, before any massive changes, with protocols mostly updated to current state.
If you have any problem with current nightly builds, try it!
It can be the candidate for intermediate Deviation release.
Welcome for testing!!! Your feedback will be helpful.
Part 1 (first 10 files)
Files deleted, see below...
Last edit: 22 Aug 2019 07:43 by vlad_vy.
15 Aug 2019 06:45 - 22 Aug 2019 07:33 #74891 by vlad_vy
Replied by vlad_vy on topic Reference nightly build Deviation v5.x.x
Part 2 (the rest 8 files)
Last edit: 22 Aug 2019 07:33 by vlad_vy.
19 Aug 2019 11:01 - 22 Aug 2019 07:32 #74928 by vlad_vy
Emulators
Last edit: 22 Aug 2019 07:32 by vlad_vy.
19 Aug 2019 11:02 - 22 Aug 2019 07:32 #74929 by vlad_vy
Emulators
Part 2 (the rest 3 files)
22 Aug 2019 07:38 - 28 Sep 2019 12:10 #74958 by vlad_vy
* Remove MUSIC_Play from protocol (#497)
* Enable optimized dfu for all devo targets
* Add V761 protocol (#881)
* Add support for Flysky AC type telemetry (#885)
22.08.2019
Last edit: 28 Sep 2019 12:10 by vlad_vy.
22 Aug 2019 07:39 - 28 Sep 2019 12:10 #74959 by vlad_vy
22 Aug 2019 07:41 - 15 Dec 2019 12:08 #74960 by vlad_vy
Emulators
Last edit: 15 Dec 2019 12:08 by vlad_vy.
22 Aug 2019 07:43 - 15 Dec 2019 12:08 #74961 by vlad_vy
Emulators
30 Aug 2019 15:53 #75057 by I.A.G.A
Replied by I.A.G.A on topic Reference nightly build Deviation v5.x.x
Hello VLAD, Many thanks for your quick reply, I was installing the last build from your link above and there is still no voice or beeps on my Jumper T8sgPlus, I've editing all of the settings into the hardware.ini about "dfplayer" and also added the voice.ini into the media map. What can I do now? The external voicemodule works well as an independend device, I was testing it and it works fine independently so it cann't be the problem. The voice module is connected to the trainerport and the wiring is the same as before my Jumper was corrupt. . I use the RC Jumper T8sgPlus bought 1 month ago. Many thanks for any answere about my questions here and have a nice weekend!
31 Aug 2019 07:32 #75064 by vlad_vy
Do you enabled in hardvare.ini
voice=dfplayer
voice-uart5=1
02 Sep 2019 18:19 - 02 Sep 2019 19:16 #75077 by I.A.G.A
Dear Vlad_VI, Many thanks for your reply, this is the whole content of my hardware.ini I've uploaded on to my T8sgPlus: Content
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
extra-switches = 2x2
extra-switches = potx2
;Audio player connected to UART (Devo12/S internally, others via trainer port): audiofx, dfplayer
voice=dfplayer
;Enable if audio device is wired to uart5 instead of ppm on devo7e-256
voice-uart5=1
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
End content
Now I was commenting by ; "voice-uart5=1" and it works for the voice module.
The beepsounds also doesn't work, no at starting up or quit the device by the on/off button. Any other idea plz.? Other readers and members of this list/topic must also answere to my request. I'm looking for the protocols for the Hubsan 502s and the MJX bugs 5W to control this drones with my T8sgPlus. . Many thanks in advance! Kind regards from Belgium! I.A.G.A.
Last edit: 02 Sep 2019 19:16 by I.A.G.A. Reason: One of the requested problems are solved about the voicemodule.
28 Sep 2019 12:24 - 29 Oct 2019 06:40 #75157 by vlad_vy
* Fix telemetry reset repeating
* Fix missed "BUTTON_REPEAT" flag
* Convert mixer beep_lock and voice_lock variables to flags (#545)
* Don't run video_setstandard in every event loop, from howard0su
* Disable "HAS_4IN1_FLASH"
28.09.2019
Last edit: 29 Oct 2019 06:40 by vlad_vy.
28 Sep 2019 12:25 - 29 Oct 2019 06:41 #75158 by vlad_vy
Last edit: 29 Oct 2019 06:41 by vlad_vy.
28 Sep 2019 16:20 #75164 by Fernandez
Replied by Fernandez on topic Reference nightly build Deviation v5.x.x
Is there a way to track all wat is inside the nightlies? Next to extra protocols
Does it include latest CRSF and PXX, does it include the HEXFET updated reduced latency/jitter changes ?
at some point can we just make version 5.1?
29 Sep 2019 07:13 #75165 by vlad_vy
It does not include latest PXX, SUMD, HEXFET reduced latency/jitter changes and latest RF scanner changes. I'm not sure I can reproduce such massive changes without errors.
01 Oct 2019 07:53 #75174 by Fernandez
Hi vlad I appreciate all your efforts and hard work and same for all developers here. But it seem you have to do lot of efforts to generate builds?
Is there not a neater way to make sure we have some kind of versioning system for test builds releases and to be able to give feedback? 5.0.1- 5.0.2 etc.
How do the do it with f.i. Betaflight project?
We do have lots of updates over 2 years
Would make reporting etc much easier? Also some improvements from developers may get lost/forgotten or stay untested somewhere, because nobody knows it excists.
29 Oct 2019 06:42 #75333 by vlad_vy
* Change SPI speed from 2.25MHz to 4.5MHz
* Fix "HAS_4IN1_FLASH" SPI speed
* Fix A7105 hanging
* Fix Radiolink SPI speed
* Fix Radiolink A7105 hanging
29.10.2019
File Attachment:
File Name: deviation-...0-29.zip
File Size:684 KB
File Attachment:
File Size:683 KB
File Attachment:
File Size:449 KB
File Attachment:
File Size:889 KB
File Attachment:
File Size:393 KB
File Attachment:
File Size:687 KB
File Attachment:
File Size:1,220 KB
File Attachment:
File Size:904 KB
File Attachment:
File Size:904 KB
File Attachment:
File Size:1,454 KB
29 Oct 2019 06:44 #75334 by vlad_vy
File Attachment:
File Size:687 KB
File Attachment:
File Size:688 KB
File Attachment:
File Size:383 KB
File Attachment:
File Size:687 KB
File Attachment:
File Size:687 KB
File Attachment:
File Size:1,221 KB
File Attachment:
File Size:1,249 KB
File Attachment:
File Size:1,247 KB
14 Dec 2019 09:35 #75582 by vlad_vy
* More efficient screen updates on devo12, from PhracturedBlue
(14.12.2019)
File Attachment:
File Name: deviation-...2-14.zip
File Size:889 KB
15 Dec 2019 11:57 #75588 by PhracturedBlue
Replied by PhracturedBlue on topic Reference nightly build Deviation v5.x.x
Uploading the builds into the forums this way is very ineficient. Please don't do it.
If you want nightly builds for the 5.x.x branch, I can help you set that up in Travis. Just open a Github tcket decribing what you want. Otherwise, you should have the ability to use the uploader script to upload your builds to the upload dir. Again if that doesn't work, contact me directly and I'll help you out with it.
Time to create page: 0.089 seconds
