Walkera FP Helicopters - Beginner settings
- Tom Z
13 Apr 2013 13:08 - 30 Apr 2014 15:23 #8913
by Tom Z
Walkera FP Helicopters - Beginner settings was created by Tom Z
This model will work on the following helicopters
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Gyro Gain is controlled with the MIX Switch. These are the values I used then converted them to the deviation values.
Switch Position 0: 50%
Switch Position 1: 78%
Switch Position 2: 82%
DR/EXPO
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
- Walkera Super FP
- Walkera Genius FP
- Walkera V200D01 w/Devo Receiver RX2437V-D
- Walkera V200D02 w/Devo Receiver RX2440V-D
- Protocol=DEVO
- TX Power=100mW
- No Fixed ID
- Throttle Hold is active on RUDD D/R switch.
- Mix Switch is Gyro Gain.
- 7 Point Throttle Curve.
Model 14 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 3 is for deviation firmware v3 and the Devo 8/8S/12.
Model 31 is for deviation firmware v3 and the Devo 10.
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:23 by Tom Z.
- 5teve457
12 Jul 2013 02:40 #12201
by 5teve457
Replied by 5teve457 on topic Walkera Super FP - Beginner settings
Is there a template for the Devo 7E? I tried using the as provided for the Devo 10, but the switches do not seem to work correctly (since the 7E only has two) and I am unable to figure out how to change the settings. I'm super new to this
The current settings are way to slow and don't give me enough servo travel. I'm sure the different rates would help, but currently I can't access them.
- Tom Z
17 Jul 2013 00:06 #12277
by Tom Z
Replied by Tom Z on topic Walkera Super FP - Beginner settings
I looked through the site and there is no template for the Devo 7E.
My models won't work correctly on the Devo 7E.
Also the DR/EXPO need special switch assignments due to the lack of switches.
Model Configs
- Walkera FP Helicopters - Beginner settings
