Blade mCPX V1/V2/BL- Standard Settings
15 Apr 2013 15:07 - 15 Feb 2014 23:31 #8957 by Tom Z
UPDATE: 5/13/13
I have updated all the models which have the same name as before.
* Notice of Ch 3 being 0 not -100 has been corrected.
* DSM2 has been changed to DSMX.
This model is for the Blade mCPX V1/V2 and mCPX BL.
  • Throttle hold on the RUDD D/R switch.
  • 7 Point Throttle and Pitch Curves.
  • TX Power=100mW
  • Channels=7
  • Protocol=DSMX
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 4 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Model 4-2 has Zero Degree Pitch when throttle hold is on.
    If you want control of the swash in TH to help you land in a crash don’t use this model use Model 4 instead.
    Model 38 is for deviation firmware v3 and the Devo 8/8S/12.
    Model 39 is for deviation firmware v3 and the Devo 10.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
Normal: 0% 40% 60% 80% 100%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Last edit: 15 Feb 2014 23:31 by Tom Z.
16 Jan 2017 16:08 #58041 by Abey
Replied by Abey on topic Blade mCPX V1/V2/BL- Standard Settings
Hi Tom Z,
thank you for all the configs you"ve posted.
Just a question for the Mcpx-bl one, I have charged the one you've offered but when I take off in normal mode the heli will lift up at around 65-75% THRO. Is there a way to have it taking off at 50% THRO at least?
In the meantime, I was used to set up the pitch of my blades using the throttle cut off, how can I do with your config? as the pitch is not moving when throttle cut is activated? I used it as well to adjust the swatchplate.
Could you please advise?
Thank you
BR
Chris
Time to create page: 0.620 seconds
