rf_module_installation
rf_module_installation [2016/04/15 12:05] FDR [Adding External Modules to Your Deviation Transmitter] |
rf_module_installation [2017/01/23 00:30] (current) FDR link |
The following modules are supported by Deviation: [[modulelist:a7105|A7105]], [[modulelist:cc2500|CC2500]], [[modulelist:nrf24l01|NRF24L01]], [[modulelist:cyrf6936|CYRF6936]]. | The following modules are supported by Deviation: [[modulelist:a7105|A7105]], [[modulelist:cc2500|CC2500]], [[modulelist:nrf24l01|NRF24L01]], [[modulelist:cyrf6936|CYRF6936]]. | ||
//NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// | //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// |
rf_module_installation.1460747116.txt.gz (9939 views) ยท Last modified: 2016/04/15 12:05 by FDR
