Line 5: | Line 5: | ||
- | - download and install the precompiled linux compiler from here: https://launchpad.net/gcc-arm-embedded | + | - download and install the pre-compiled Linux compiler from here: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads |
- | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-4_8-2013q4-20131204. You can find the link to this from here: https://launchpad.net/gcc-arm-embedded/+download | + | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-8-2018-q4. You can find the link to this from here: https://developer.arm.com/-/media/Files/downloads/gnu-rm/8-2018q4/gcc-arm-none-eabi-8-2018-q4-major-linux.tar.bz2 |
- Add the path to the 'bin' directory to your PATH | - Add the path to the 'bin' directory to your PATH | ||
- | - Download and install the precompiled windows compiler from here: https://launchpad.net/gcc-arm-embedded | + | - Download and install the precompiled windows compiler from here: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads |
- | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-4_8-2013q4-20131204. You can find the link to this from here: https://launchpad.net/gcc-arm-embedded/+download | + | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-8-2018-q4. You can find the link to this from here: https://armkeil.blob.core.windows.net/developer/Files/downloads/gnu-rm/8-2018q4/gcc-arm-none-eabi-8-2018-q4-major-win32.zip |
- Add path to 'bin' directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''export PATH=/mingw/stm32/bin:$PATH'' | - Add path to 'bin' directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''export PATH=/mingw/stm32/bin:$PATH'' | ||
- Ensure python is installed. If not install it from here: http://www.python.org/download/releases/2.7.3/ | - Ensure python is installed. If not install it from here: http://www.python.org/download/releases/2.7.3/ |
development/setting_up_build_env.1462043696.txt.gz (25281 views) · Last modified: 2016/04/30 12:14 by FDR
