get_started_with_deviationtx [2016/05/03 21:55] Arnold [First you need a TX] |
Line 9: | Line 10: | ||
Line 16: | Line 17: | ||
- | * **"Official" releases, like the 5.0.0** \\ From time to time there is a release, which is tested, and gets a round version number, however they are rare. The last one is 5.0 and was released the 30/05/2016. | + | * **"Official" releases, like the 5.0.0** \\ From time to time there is a release, which is tested, and gets a round version number, however they are rare. The last one is 5.0 and was released the 30/04/2016. |
* DSM2 | * DSM2 | ||
* DSMX | * DSMX | ||
Line 58: | Line 59: | ||
get_started_with_deviationtx.1462337740.txt.gz (682 views) · Last modified: 2016/05/03 21:55 by Arnold
