hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/10 06:27] csujun remove PA08 |
hardware:radiolink_at10 [2019/02/21 17:03] csujun red led connects PC12 |
Line 5: | Line 5: | ||
Line 26: | Line 26: | ||
Line 62: | Line 61: | ||
|PC14 | ENC R | Rotary Encoder | 10K pull-up | | |PC14 | ENC R | Rotary Encoder | 10K pull-up | |
hardware/radiolink_at10.txt (111001 views) ยท Last modified: 2019/02/27 05:25 by csujun
