hardware:radiolink_at9
hardware:radiolink_at9 [2016/04/20 07:21] PhracturedBlue |
hardware:radiolink_at9 [2019/02/27 05:21] csujun add PD6 |
The following documents the hardware inside the Radiolink AT9 transmitter | The following documents the hardware inside the Radiolink AT9 transmitter | ||
- | * MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VCT6]] 512kB Flash, 64kB RAM 100pin package | + | * MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VET6]] 512kB Flash, 64kB RAM 100pin package |
- | * EEPROM: [[http://pdf1.alldatasheet.com/datasheet-pdf/view/310964/ISSI/IS25C128A-2GLI/+2119J7VGRSpbKUtzpNzhKKEyZV+/datasheet.pdf|IS25C128A-2GLI]] 128K-bit SPI SERIAL EEPROM | + | * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM |
- | * LCD Driver: ILI9345? based 320x240x16color display | + | * LCD Driver: ILI9341 based 320x240x16bit display |
- | ==== STM32 Connections ==== | ||
- | ^Pin ^Desription ^ | ||
Line 22: | Line 20: | ||
+ | |PA04 | POT | Right Shoulder | | | ||
+ | |PA05 | POT | Left Front Dial | | | ||
+ | |PA06 | POT | Right Front Dial | | | ||
Line 31: | Line 32: | ||
|PB04 | TRR | Right Trim Right | | | |PB04 | TRR | Right Trim Right | | | ||
Line 72: | Line 75: | ||
+ | |PD06 | USB Detect | Detect USB Plugin | | | ||
|PD09 | DISP17 | Data | | | |PD09 | DISP17 | Data | | | ||
Line 83: | Line 87: | ||
- | |PE00 | DISP19 | Control | | | + | |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | |
Line 95: | Line 99: | ||
+ | | 15.05V | 0x0FFB | | ||
+ | | 10.02V | 0x0A9D | | ||
+ | | 4.31V | 0x048E | | ||
=== FCC Report === | === FCC Report === |
hardware/radiolink_at9.txt (185811 views) · Last modified: 2019/02/27 05:21 by csujun
