hardware:wfly_et07
hardware:wfly_et07 [2019/02/23 03:26] (current) csujun created |
+ | ~~TOC:3-4~~ | ||
+ | ===== WFLY ET07 Hardware Connections ===== | ||
+ | The following documents the hardware inside the Radiolink AT9 transmitter | ||
+ | * MCU: [[https://www.st.com/resource/en/datasheet/stm32f407ve.pdf|STM32F407VET6]] 512kB Flash, 64kB RAM 100pin package | ||
+ | * EEPROM: [[http://html.alldatasheet.com/html-pdf/99362/ATMEL/AT25128A/127/1/AT25128A.html|ATMLH712]] 128K-bit SPI SERIAL EEPROM | ||
+ | * LCD Display: ?? | ||
+ | * LCD Driver: ?? | ||
+ | * Radio: A7105 | ||
+ | * Touch: [[http://www.ti.com/cn/lit/gpn/tsc2046|TSC2046]]4-Wire Touch Screen Controller with low voltage digital I/O | ||
+ | * DC/DC converter: ?? | ||
+ | ==== STM32 Connections ==== | ||
+ | ^Pin ^Connection ^Description ^Additional Info^ | ||
+ | |BOOT0 |BOOT0 | | | | ||
+ | === GPIOA === | ||
+ | |PA00 | CH1 | SRH RIght Hor Stick | | | ||
+ | === GPIOB === | ||
+ | === GPIOC === | ||
+ | |PC00 | K1A | 2-pos switch | | | ||
+ | === GPIOD === | ||
+ | |PD00 | DISP5 | Data | | | ||
+ | === GPIOE === | ||
+ | |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | | ||
+ | | 15.05V | 0x0FFB | | ||
+ | | 10.02V | 0x0A9D | | ||
+ | | 4.31V | 0x048E | | ||
+ | === FCC Report === | ||
+ | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page| U2B RL039AT9]] | ||
hardware/wfly_et07.txt (32512 views) ยท Last modified: 2019/02/23 03:26 by csujun
