release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 09:51] PhracturedBlue |
release_notes:5.0.0 [2017/01/23 00:43] FDR https |
* Allow reordering mixers on Devo7e/10 | * Allow reordering mixers on Devo7e/10 | ||
- | ==== Minor Features ==== | + | ==== Minor Features / Bug Fixes ==== |
* Support hardware modification to add extra switches to the devo7e | * Support hardware modification to add extra switches to the devo7e | ||
* Support hardware modification to add vibration for Devo6/8 | * Support hardware modification to add vibration for Devo6/8 | ||
Line 17: | Line 23: | ||
* Support smaller fonts in Devo7e | * Support smaller fonts in Devo7e | ||
* Improve volume control | * Improve volume control | ||
+ | * Fix date displays | ||
Line 22: | Line 40: | ||
- | * DSM2/X telemetry display fixes | + | * DSM2/X - telemetry display fixes. Support temperature display |
- | * Show dialog for WK* protocols until biding is complete | + | * DSM2/X - support extended telemetry info |
- | * New protocols: | + | * DSM2/X - fix GPS heading units |
+ | ==== New protocols ==== | ||
* SymaX | * SymaX | ||
- | * Fix date displays | + | * Frsky 2-way and V8 protocols |
- | ==== Critical bug fixes ==== | + | * YD717 now supports Sky Walker 1306 |
- | * DSM2/DSMX fixes for lost binding during operation | + | * YD717 supports XinXun |
+ | * H377 protocol | ||
+ | * HM380 protocol | ||
+ | * KN (V977) protocol | ||
+ | * ESky150 protocol | ||
+ | * Bluefly HP100 | ||
+ | * CX10 protocol | ||
+ | * Joysway protocol | ||
+ | * Hontai protocol | ||
+ | * FY326 protocol | ||
+ | * MJXq protocol | ||
+ | * H8_3d protocol | ||
release_notes/5.0.0.txt (23358 views) · Last modified: 2017/05/17 08:03 by Texacate
