release_notes:5.0.0
release_notes:5.0.0 [2017/01/23 00:43] FDR https |
Line 2: | Line 2: | ||
**IMPORTANT:**\\ | **IMPORTANT:**\\ | ||
**You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | **You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | ||
- | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like it was in the last nightly builds.** | + | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.** |
Line 40: | Line 40: | ||
* DSM2/X - telemetry display fixes. Support temperature display | * DSM2/X - telemetry display fixes. Support temperature display |
release_notes/5.0.0.txt (23313 views) ยท Last modified: 2017/05/17 08:03 by Texacate
