release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 12:59] Arnold [Minor Features / Bug Fixes] |
- | ** NOTE: Deviation 5.0.0 has not been released yet. These release notes are a work-in progress** | + | Version 5.0.0 was released on 2016-04-30 |
Line 40: | Line 42: | ||
Line 76: | Line 78: | ||
release_notes/5.0.0.1462046366.txt.gz (22898 views) · Last modified: 2016/04/30 12:59 by Arnold
