rf_module_installation:enabling_modules
rf_module_installation:enabling_modules [2016/04/15 09:09] FDR [Introduction] |
rf_module_installation:enabling_modules [2016/04/15 12:02] (current) FDR [Enabling External Modules to Your Deviation Transmitter] |
===== Enabling External Modules to Your Deviation Transmitter ===== | ===== Enabling External Modules to Your Deviation Transmitter ===== | ||
==== Introduction ==== | ==== Introduction ==== | ||
The Deviation firmware implements several protocols that the Devo series radios do not have the necessary hardware to support. To use these protocols, it is necessary to install additional 2.4GHz transceiver modules. Please see [[:rf_module_installation|Module Installation]] for instructions on how to do that. After you have added the modules, you must enable them by editing the hardware description in files on the transmitter file system. | The Deviation firmware implements several protocols that the Devo series radios do not have the necessary hardware to support. To use these protocols, it is necessary to install additional 2.4GHz transceiver modules. Please see [[:rf_module_installation|Module Installation]] for instructions on how to do that. After you have added the modules, you must enable them by editing the hardware description in files on the transmitter file system. |
rf_module_installation/enabling_modules.1460736594.txt.gz (25236 views) ยท Last modified: 2016/04/15 09:09 by FDR
