sticky_throttle_hold
sticky_throttle_hold [2017/09/06 05:24] mwm created |
sticky_throttle_hold [2017/09/06 12:24] (current) Moeder fix display of ini code |
Line 5: | Line 5: | ||
You can use a virtual channel as a switch with that property. The channel uses three mixers. The first one uses the old value of that channel, setting it to 100 or -100 with a min/max curve. The second mixer adds the current throttle output to that value with an offset, so that unless the throttle output is -100 or lower, the resulting switch will be on. The last mixer uses a physical switch to set the channel on if that switch is on, otherwise it leaves it at the last value. | You can use a virtual channel as a switch with that property. The channel uses three mixers. The first one uses the old value of that channel, setting it to 100 or -100 with a min/max curve. The second mixer adds the current throttle output to that value with an offset, so that unless the throttle output is -100 or lower, the resulting switch will be on. The last mixer uses a physical switch to set the channel on if that switch is on, otherwise it leaves it at the last value. | ||
+ | <code> | ||
[virtchan1] | [virtchan1] | ||
name=T Hold | name=T Hold | ||
Line 26: | Line 28: | ||
usetrim=0 | usetrim=0 | ||
curvetype=fixed | curvetype=fixed | ||
+ | </code> |
sticky_throttle_hold.1504700689.txt.gz (67619 views) ยท Last modified: 2017/09/06 05:24 by mwm
