transmitter:devo7e
transmitter:devo7e [2016/05/08 13:11] silpstream Fix links |
transmitter:devo7e [2016/05/09 07:45] silpstream |
Line 24: | Line 26: | ||
Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | == Disassembly == | ||
- | Alternatively you can [[:building_the_multi-module|build]] the [[:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. | + | Alternatively you can [[:building_the_multi-module|build]] the [[modulelist:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. |
The process is very well documented in the wiki page "[[:rf_module_installation|RF Module Installation]]". | The process is very well documented in the wiki page "[[:rf_module_installation|RF Module Installation]]". | ||
+ | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum | ||
Line 75: | Line 120: | ||
transmitter/devo7e.txt (84175 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
