transmitter:devo7e
transmitter:devo7e [2016/05/09 07:45] silpstream |
transmitter:devo7e [2016/06/02 01:12] silpstream add link to 4-in-1 |
Line 58: | Line 58: | ||
*[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | ||
*[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | ||
+ | *[[http://www.deviationtx.com/forum/how-to/5955-7e-ultimate7e-adding-the-devo-version-4in1|7e/Ultimate7e, adding the devo version 4in1]] by HappyHarry in our forum | ||
Line 81: | Line 82: | ||
The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port. | The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port. | ||
+ | *[[http://www.deviationtx.com/forum/7-development/4442-extra-inputs-for-devo-tx-s?limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum | ||
Line 95: | Line 98: | ||
Adding higher power handling regulators for the extra load due to the RF module upgrades. | Adding higher power handling regulators for the extra load due to the RF module upgrades. | ||
- | + | *[[http://www.deviationtx.com/forum/6-general-discussions/2910-devo-7e-a7105pa-range-mod-current-draw?start=20#24372|AMS1117 Replacement Regulator]] by Fernandez in our forum | |
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/5307-problem-with-overvolted-devo7e#43231|Pololu 3.3V Step-Up/Step-Down Voltage Regulator]] by Fernandez in our forum | ||
Have an LED light up when the power is turned on. | Have an LED light up when the power is turned on. | ||
Line 124: | Line 130: | ||
transmitter/devo7e.txt (84192 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
