DEVO 10 : AUX4 & AUX5
24 Nov 2012 16:26 #3117 by domcars0
DEVO 10 : AUX4 & AUX5 was created by domcars0
I've just downloaded ,compiled and installed the last (some hours ago) sunvsuv commit and have begin to play with deviation on my Devo 10 :P
First of all, thanks for this wonderfull work!!
There is one thing I can't configure (or is a bug?).
This is about the Aux4 and Aux5 in DEVO Protocol, they are recognize as switches (and work) but not as potentiometers (proportional) ...
Is there any way to configure it the right way?
Another thing is how to configure "Throttle Hovering" and "Pitch Hovering" on the Left and Right Trim?
Thanks for your help.
Sorry for my frenglish.
24 Nov 2012 16:34 #3118 by suvsuv
Replied by suvsuv on topic DEVO 10 : AUX4 & AUX5
During stick calibration, you have to do it for Aux4&5 as well:
1)Move 4 sticks , aux4 and aux 5 into their central position, then press ENT
2) Move All the 4 sticks and 2 AUX knobs from min to max postions, then press ENT
Once you see Calibration Done, you will get AUX4 and 5 work as proportional channels
24 Nov 2012 16:50 - 24 Nov 2012 16:52 #3119 by domcars0
Replied by domcars0 on topic DEVO 10 : AUX4 & AUX5
suvsuv wrote: During stick calibration, you have to do it for Aux4&5 as well:
Hi suvsuv,
You are right! It works ...thank you.
A (very) small bug (but which may be hide a more serious futur one) :
Once we have the 'calibrate done.' message, if we continue by pressing the 'Ext' (not the 'Enter') button, we gat a 'strange mixed page'?
Press 'Ext' again to have a normal page.
Do I need to submit this small bug one the bug tracker ?
Thanks again.
PS: May be the message have to be : "Calibrate done, press 'Ent' to continue."
Last edit: 24 Nov 2012 16:52 by domcars0.
24 Nov 2012 16:57 #3121 by suvsuv
The bug you mentioned has been fixed 2 hours ago .
24 Nov 2012 19:11 - 24 Nov 2012 20:03 #3125 by domcars0
OK you are too much for me :silly:
May I give you a new (attached) release french language file ...
[EDIT] : sorry "Timer1:", "Timer2:" and "Press ENT to turn USB drive:" are well translate...I will give you a better lang.fr later.
File Attachment:
File Name: lang_fr.txt
File Size:4 KB
Last edit: 24 Nov 2012 20:03 by domcars0.
24 Nov 2012 20:04 #3126 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 10 : AUX4 & AUX5
domcars0 wrote: OK you are too much for me :silly:
NB : seems that "Timer1:" and "Timer2:" are not translate()?
[EDIT] :sorry "Press ENT to turn USB drive:" is well translate...I will give you a better lang.fr later.
File Attachment:
File Size:4 KB
Please open a ticket on itbucket with your updated translations. It is the only way I can reliably keep track of them.
24 Nov 2012 20:15 #3128 by domcars0
@PB: OK I will ...thanks
24 Nov 2012 20:44 #3129 by FDR
Replied by FDR on topic DEVO 10 : AUX4 & AUX5
domcars0 wrote: Another thing is how to configure "Throttle Hovering" and "Pitch Hovering" on the Left and Right Trim?
I've made a template for it:
www.deviationtx.com/forum/model-template...-with-hovering-trims
24 Nov 2012 21:09 #3130 by domcars0
Thanks FDR ,I will take a look on it.
15 May 2020 07:11 - 15 May 2020 07:11 #76312 by nl2rma
Replied by nl2rma on topic DEVO 10 : AUX4 & AUX5
Many thanks to suvsuv I was trying to configure the Aux1 for hours on my F7 but after calibration and also turning the knob aux1 finaly worked proportional.
Last edit: 15 May 2020 07:11 by nl2rma.
Time to create page: 0.064 seconds
