Hubsan x4 (H107) Support
- rototophe
heliaddict wrote: Not sure why they put it in expert mode before calibrating. I have tried in both modes and it works so not sure if it really makes any difference?
Thanks for your answer
Yes that was the video I was referring to. I thought that maybe they do the calibration in high rates to somewhat set the gyro mode. Something like tell the quad what the full travel is, then it would not allow flipping if the stick travel is less than x% of what was detected during calibration. Again, I may be thinking too much ...
I must say the the accelerometer does work extremely well on this quad and I personally prefer it over the Ladybird. It flips fast and in very tight spaces and also recovers very quick. Its very impressive especially for the low cost.
Mine is coming in tomorrow, looking forward to it after your comments and all the good stuff I read about that little thing. I literally love my ladybird so I guess this will be great!
Sad thing to have to get another useless Tx that will end up in the bin, sad for the environment and sad for my wallet as well!
- Joshua
www.revell-control.de/quadrocopter/neu-m...xs-series-rtf4chghz/
- jazzjohn
Exactly what module do I need... still the A7105-500m as mentioned 8 months ago?
Also, if a module is added can it peacefully coexist with the stock Devo module and does the Deviation firmware turn off one when the other is in use? I am a little unclear of the overview for multiple modules.
Thanks.
- jazzjohn
Would this module work in a Devo 6 to control a Hubsan X4 quad?
Thanks.
- victzh
- jazzjohn
If that's the case, then it does make more sense to use the higher-output module.
- victzh
Power conservation should not be that essential - 100mW module theoretically can run from 5v 20mA, or 3.3v 33mA. Usually some losses means that it is more close to 3.3V 40-50mA. Linear power supply used in Devo dominates these power losses with big margin, so if you're power conscious you should care more about enhancing Devo's power electronics than reducing power of your radio.
- jazzjohn
I am not concerned about the linear power supply losses since I get good transmit time with Ni-MH batteries.
Edit: Just found the answer here .
The transmit function is inhibited when Hubsan is not selected. As it should be!
- willpc
- Hubsan x4 (H107) Support
