- How do I set the CCPM type for "single servo"
- Rain4LA
05 Feb 2013 17:05 #6054
by Rain4LA
How do I set the CCPM type for "single servo" was created by Rain4LA
I apparently need to set the CCPM type for single servo for my 130x, and can't seem to figure it out.
I am the eternal newb.
Thank you.
Thank you.
- Joshua
05 Feb 2013 17:18 #6055
by Joshua
Replied by Joshua on topic How do I set the CCPM type for "single servo"
I use this config file for my 130X.
name=Blade 130x
[radio]
protocol=DSM2
num_channels=6
tx_power=100mW
[channel1]
max=100
min=-100
template=complex
[mixer]
src=THR
dest=Ch1
switch=FMODE0
curvetype=5point
points=-100,-20,20,36,100
[mixer]
src=THR
dest=Ch1
switch=FMODE1
usetrim=0
curvetype=5point
points=50,50,50,50,50
[mixer]
src=THR
dest=Ch1
switch=RUD DR
scalar=-100
usetrim=0
curvetype=fixed
[channel2]
max=100
min=-100
template=expo_dr
[mixer]
src=AIL
dest=Ch2
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Ch2
switch=ELE DR
scalar=75
curvetype=expo
points=50,50
[channel3]
max=100
min=-100
template=expo_dr
[mixer]
src=ELE
dest=Ch3
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Ch3
switch=ELE DR
scalar=80
curvetype=expo
points=50,50
[channel4]
max=100
min=-100
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=65
[channel6]
max=100
min=-100
scalar=70
template=complex
[mixer]
src=THR
dest=Ch6
switch=FMODE0
usetrim=0
curvetype=5point
points=-100,-50,0,50,100
[mixer]
src=THR
dest=Ch6
switch=FMODE1
usetrim=0
curvetype=5point
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=5
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=5
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=5
[timer1]
type=countdown
src=THR
time=360
[safety]
[gui-qvga]
trim=4in
barsize=half
box1=Ch1
box2=timer1
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=FMODE1
tglico2=3
ciao, Bernd
name=Blade 130x
[radio]
protocol=DSM2
num_channels=6
tx_power=100mW
[channel1]
max=100
min=-100
template=complex
[mixer]
src=THR
dest=Ch1
switch=FMODE0
curvetype=5point
[mixer]
src=THR
dest=Ch1
switch=FMODE1
usetrim=0
curvetype=5point
[mixer]
src=THR
dest=Ch1
switch=RUD DR
scalar=-100
usetrim=0
curvetype=fixed
[channel2]
max=100
min=-100
template=expo_dr
[mixer]
src=AIL
dest=Ch2
curvetype=expo
points=0,0
[mixer]
src=AIL
dest=Ch2
switch=ELE DR
scalar=75
curvetype=expo
points=50,50
[channel3]
max=100
min=-100
template=expo_dr
[mixer]
src=ELE
dest=Ch3
curvetype=expo
points=0,0
[mixer]
src=ELE
dest=Ch3
switch=ELE DR
scalar=80
curvetype=expo
points=50,50
[channel4]
max=100
min=-100
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=65
[channel6]
max=100
min=-100
scalar=70
template=complex
[mixer]
src=THR
dest=Ch6
switch=FMODE0
usetrim=0
curvetype=5point
[mixer]
src=THR
dest=Ch6
switch=FMODE1
usetrim=0
curvetype=5point
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=5
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=5
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=5
[timer1]
type=countdown
src=THR
time=360
[safety]
[gui-qvga]
trim=4in
barsize=half
box1=Ch1
box2=timer1
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=FMODE1
tglico2=3
ciao, Bernd
- Rain4LA
05 Feb 2013 17:53 #6056
by Rain4LA
Replied by Rain4LA on topic How do I set the CCPM type for "single servo"
Could you possibly drop in the .ini file? I would really appreciate it!
- Rain4LA
05 Feb 2013 18:15 #6057
by Rain4LA
I figured it out... Thank you!!!
- Hexperience
05 Feb 2013 19:10 #6059
by Hexperience
Replied by Hexperience on topic How do I set the CCPM type for "single servo"
Don't know how many times I've forgotten that some of those selection boxes are also buttons.... Age.
- Thomas.Heiss
04 Jul 2015 13:09 #35094
by Thomas.Heiss
Replied by Thomas.Heiss on topic How do I set the CCPM type for "single servo"
Older thread but I still want to other to make it clear for other newbies seeking help:
1. Model setup / Model type: Heli
-> Press ENT button
2. Change "Swashtype" setting to "None" (default).
No, "90" is really a 3 CCPM setup, thats NOT the same as Spektrum DX8 Airware "1x 90 setting" which you would choose for FBL.
BTW:
On FBL helis (e.g Blade NanoCPX, 130X) with no active CCPM mixing you can use on the pitch channel:
- subtrim: for 0 degree zero pitch (only if there is no advanced FBL system which needs to be programmed)
- two servo travels (scale+-): for max and min pitch adjustment
Thomas
-> Press ENT button
BTW:
Thomas
Time to create page: 0.027 seconds
