Devo 8s orange rx recievers
- ledfreak3d
Anybody knows if the orange rx recievers range should work correctly with deviation release 3.0,0
Sometimes i am able to bind but most of the times it wont.
and if it does its highly unstable and responds badly to the tx
i currently have a orange rx 710 series
see below
www.hobbyking.com/hobbyking/store/__2068...iver_w_Failsafe.html
All my walkera r801 recievers work fine but ofcourse those are not dsm2
- stevecox
- Keep swinging
Adelaide
- ledfreak3d
are you using any special settings ?
- stevecox
- Keep swinging
Adelaide
- ledfreak3d
i just use the bind button in the model settings.
but in my case the led never goes to solid Always remains blinking or goes in a sort of randomly blinking mode
- BitOne
I mostly used Orange RX with my planes (2x R410 and 1 R415) and my Devo8S. I have a R600 somewhere, I can try it too if you need.
Never had problem at all with DeviationTx, which I use since version 2.1.1.
Here is the binding process I follow:
- plug the bind plug into the RX
- switch on the TX
- switch on the RX (it must blink rapidly but at a constant rate) Be careful that the RX is not to close to the TX. 1 or 2 meters is ok.
- click on the Bind button on the TX
- the LED should go solid on the RX
- remove the bind plug
- switch off the RX
- switch off the TX
Then:
- switch on the TX
- switch on the RX
=> must beep a little bit then after 2-5 seconds, the LED on the TX should switch on.
It you follow this process, and you never get a solid bind, your RX is maybe faulty. You should try to bind on another Orange or Spektrum RX to see if the problem comes from your RX or your TX...
Good luck !
- ledfreak3d
seems like im doing it the right way
maybe im sitting to close to the rx ?
- BitOne
Could be that or you've got a faulty unit.ledfreak3d wrote: thanks Bitone
One more possibility: you could be in very noisy environment from a 2.4Ghz point. For example, if you're trying to bind close to a Wifi access point, it could bring some problem I suppose. So try to switch it off or get far from it. Or you have a microwave that is running each time you try to bind
But my advise would be to get a new R615 Orange RX from HobbyKing or a LemonRX 6 channels from lemon-rx.com and try it again with your Devo 8S. It would cost you less than 10$ and if you're lucky you could get an Orange one with fast shipping from a local warehouse.
And you will directly get your answer if the fault is on the Devo side (unlikely, as it works with Walkera RX) or on your current Orange RX.
- ledfreak3d
ill try some more this evening when im home
and else ill just order a other rx when there back in stock
dont realy need it but always handy to have a spare specialy at those prices
- ledfreak3d
need to find a other dsm2 rx to test with
- ledfreak3d
But
its seems the channels still get mixed up
i fly my devo 8 in mode 2
so my left stick is throttle but when binding to the orange rx
it thinks my right stick is throttle
even complains during power on that my stick is not in a safe position witch it issent because its in the middle
im prety sure im overlooking something
- Wene001
1 throttle
2 Aileron
3 Elevator
4 rudder
or set the protocol to dsm first and load a template in the second step then the channels are automativ in the right order to the protocol
- bastien
- ledfreak3d
- ledfreak3d
no issues with the devo recievers
- ledfreak3d
just some minor issues to solve my throtle % display it no linked to pitch
- Devo 8s orange rx recievers
