binding futaba with devo 10?
14 Sep 2014 19:50 #25660 by olongapso
binding futaba with devo 10? was created by olongapso
hi guys, any way to bind a futaba rx with deviation and devo10?
15 Sep 2014 04:19 #25676 by FDR
Replied by FDR on topic binding futaba with devo 10?
Still no.
15 Sep 2014 11:38 #25681 by olongapso
Replied by olongapso on topic binding futaba with devo 10?
tks
and any other receiver, i.e. hobby king model or similar ones?
15 Sep 2014 11:55 #25682 by FDR
You can use any DSM2 or DSMX receivers (made by Spektrum, OrangeRX or LemonRX), or any Walkera receivers (WK or DEVO) without modification.
With an additional RF modul you can use Flysky (Turnigy) receivers, as stated on the Home page.
Here is a detailed table about receiver compatibility:
docs.google.com/spreadsheet/ccc?key=0Any...kE&usp=sharing#gid=0
15 Sep 2014 17:57 #25685 by olongapso
perfect, thanks so much for help
29 Apr 2015 20:26 #31819 by olongapso
so, this receiver shall be used with a devo10?
shop.lindinger.at/product_info.php?products_id=95296
29 Apr 2015 20:59 #31820 by Fernandez
Replied by Fernandez on topic binding futaba with devo 10?
The new futaba transmitters using s-FHSS (not the older fasst) seem to run cc2500, so it could be technically possible I assume.
But I have no seen any clones rx or cracked of the s-FHSS protocol
30 Apr 2015 01:52 #31825 by aMax
Replied by aMax on topic binding futaba with devo 10?
30 Apr 2015 07:15 #31834 by victzh
Replied by victzh on topic binding futaba with devo 10?
Protocol reverse engineering requires both TX and RX. While I imagine someone buying the (compatible, not original) RX for $30 for the sole purpose of reverse engineering this protocol, I can't imagine someone doing this with $160 minimum 6-ch TX. And to cover the protocol you need to use high channel count high price equipment (14ch - around $600).
30 Apr 2015 12:27 #31849 by Fernandez
Ah didn't see those receivers, but it confirms it could technically be cloned :)
Futaba = expensive and not openHowver I could imagine there are people out here with dozens of the older fasst rx which they like to use in deviation, but those use different chip, so can't work anyway.
Buying today the new expensive futaba S-FHSS rx to me makes no sense Better go for Frsky .
An interesting RX candidate to develop would be the new flysky AFHDS-2a, has telemetry port on the rx and diversity and good range,very cheap, half price frsky. If this would work in Deviation, would use that.
25 Jun 2015 20:01 #34658 by olongapso
hi guys
I have buyed an orange receiver dsmx/dsm2 type; works correctly, bind without problem but during setup on my radio I find different channel on radio; generallywith devo protocol I have 1)ele, 2) ail, 3)thr, 4)rud; with dsm2/dsmx I have 1)thr, 2)ail, 3)ele, 4)rud. how can I change channels?
thanks
Luca
26 Jun 2015 08:07 #34663 by linux-user
Replied by linux-user on topic binding futaba with devo 10?
olongapso wrote: generallywith devo protocol I have 1)ele, 2) ail, 3)thr, 4)rud; with dsm2/dsmx I have 1)thr, 2)ail, 3)ele, 4)rud. how can I change channels?
The channel-order is hard coded in the RX. But you can easily select which stick (or switch) operates the channel.
Just select "source" in the mixer page.
26 Jun 2015 09:19 #34669 by mwm
Replied by mwm on topic binding futaba with devo 10?
olongapso wrote: hi guys
thanks
Luca
That's the standard order for DSMx radio gear.
If you haven't connected the Rx up yet, just go with it. Plug the throttle, aileron, elevator, and rudder into the servos with those labels on the Rx.
If you've already connected up the Rx and ignored those labels, then do what linux-user suggested, and change which stick input goes to which channel. The easy way to do that is to use the channel reorder feature. Hold down R+ on the mixer page, and then move them to the right place..
26 Jun 2015 19:13 #34695 by olongapso
Thanks guys, problem solved.
just one issue remain unsolved: servos works correctly but motor continue to beep fast (that means error) and do not responde to stick movement.
I tried motor with other devo receiver and works correctly.
any suggestion?
26 Jun 2015 19:37 #34696 by mwm
Fernandez wrote: Ah didn't see those receivers, but it confirms it could technically be cloned :)
Just for the record, Futaba will license their protocols to you, and let you sell under the logo "FTR" for Futaba Ready. Those may well be licensed copies, not reverse engineered clones.
Time to create page: 0.039 seconds
