Devo protocol FixedID question
- dr.wagen
11 Jan 2016 17:25 - 11 Jan 2016 17:27 #41636
by dr.wagen
Devo protocol FixedID question was created by dr.wagen
I have Devo7 and several Devo receivers. They bind with FixedID (for example 11911) .
I entered same ID into Devo10 with Deviation, but receivers not connect.
Is it possible have same ID on both TX?
And one more note - I can't set FixedID in Deviation with leading zero.
Last edit: 11 Jan 2016 17:27 by dr.wagen.
- TomPeer
11 Jan 2016 18:09 #41638
by TomPeer
Replied by TomPeer on topic Devo protocol FixedID question
Fixed ID will only work with the transmitter you used when setting the fixed ID. It will not work with other transmitters, even if you use the same number. Every transmitter has its own ID number witch is also a part of the binding with fixed ID.
- dr.wagen
11 Jan 2016 18:41 #41641
by dr.wagen
Replied by dr.wagen on topic Devo protocol FixedID question
Ok. Thanks.
- Fernandez
11 Jan 2016 19:08 #41642
by Fernandez
Replied by Fernandez on topic Devo protocol FixedID question
Interesting question, I was also wondering about that, 6 digits for binding is not really very much, so it could be, that you are unlucky,and some one use same code.
But as i understand still not possible tocontrol the model.
How many total combinations, or Bind-ID's + transmitter-ID are there? Or whats the chance someone controls your model?
11 Jan 2016 20:09 #41643
Replied by FDR on topic Devo protocol FixedID question
While what TomPeer said was right, i.e. the binding data consists of the fixed (or automatic) id and the id of the transmitter chip, in deviation you can simulate an other tx id, so if you have two transmitters, you can setup both to use the same tx id. This way you can bind a model to both transmitters, and you can control it with either one.
Hovever there is no simple way to know, what tx id your devo 7 uses, to set it up for your devo 10...
- dr.wagen
11 Jan 2016 20:31 #41645
by dr.wagen
Sounds optimistic.
I don't know is my case so interesting for all, but now I using both TX.
Study Deviation on Devo 10 and fly on Devo 7
Any way FDR thanks for great firmware!
11 Jan 2016 21:47 #41647
It wasn't me who made it...
- TomPeer
12 Jan 2016 18:28 #41681
by TomPeer
Yes,
I have 4 devo transmitters, and indeed use deviation to give them all the same id number.
I did not mention that because dr. wagon has a devo 7, with witch deviation can not be used,
But indeed FDR is absolutely right with deviation you can use a fixed ID with more transmitters.
- quique65
12 Jan 2016 21:17 #41691
by quique65
Replied by quique65 on topic Devo protocol FixedID question
Hello. I have a 7e and 6s. How can I setup the same Tx id on both?. Thanks in adcance.
- TomPeer
13 Jan 2016 13:16 - 13 Jan 2016 13:43 #41711
by TomPeer
Edit your hardware ini.
This is mine. Change the number after txid=
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
txid = 86668963
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
; enable-multimod = A13
Give each tx the same number.
;enable-haptic=1
;extra-switches=
txid = 86668963
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
; has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 13 Jan 2016 13:43 by TomPeer.
- quique65
14 Jan 2016 06:34 #41739
by quique65
Perfect. Thanks for your help.
Time to create page: 0.039 seconds
- Devo protocol FixedID question
