Flybarless Template needed
07 Feb 2016 21:34 #42742 by aperseghin
Flybarless Template needed was created by aperseghin
There is a generic 6 Channel Heli template but not a flybarless one.
I have been reading this
www.deviationtx.com/forum/how-to/1226-ho...s-on-custom-firmware
And it seems like the template should be rather simple but im still struggling with it a bit. Im trying to learn a lot of concepts all at once. What I really need is a model config for a Devo 10 to use with a 450 flybarless (vbar) bird.
The closest thing I can find is the Master CP model config. Can someone make a config or a template for flybarless?
08 Feb 2016 11:28 #42764 by Thomas.Heiss
Replied by Thomas.Heiss on topic Flybarless Template needed
Personally I just use the supplied 6CH heli template and set CCPM mixer to None.
You just have to use the settings for pitch/throttle curves on the virtual Cyclic1-3 channels and not the first real channels.
Take care of mapping the correct order of ELEV vs AIL cyclic servo channels to cyclic1-2.
Done.
You do not really need a new template.
If you really like you could setup a fresh configuration by additionally adding THR stick to 6CH pitch channel and setup the appropriate pitch curves and map 3 to FMode1-3 and 4th to Hold switch.
Thomas
08 Feb 2016 13:16 #42767 by vlad_vy
Replied by vlad_vy on topic Flybarless Template needed
Any existing FBL config can be template for any FBL heli, they all are very simple. All main work will do FBL controller.
Time to create page: 0.022 seconds
