- New Firmware V5.0 something wrong of Devo6S
- Li
18 Jul 2016 15:40 #51834
by Li
New Firmware V5.0 something wrong of Devo6S was created by Li
I just updated new firmware V5.0 for my Devo 6S. I checked all item and chose Helicopter mode
3 servo SwashType 120 and DEVO Protocol for my Walkera Mini CP, I found of servos wrong control,
the AIL and ELE control signal interchanged !! I have tried another one Skyartec Nano CP also same
problem of ELE and AIL control !!
I don't know how to fix it ???
- HappyHarry
18 Jul 2016 17:29 #51839
by HappyHarry
Replied by HappyHarry on topic New Firmware V5.0 something wrong of Devo6S
you need to swap the swash type to 120x, this issue was caused by someone who complained that his heli was working wrong when he didn't try 120x, now the majority of heli's who have the correct swash/servo setup have to use 120x instead of the rare few who have it backwards
18 Jul 2016 18:02 #51841
Replied by FDR on topic New Firmware V5.0 something wrong of Devo6S
Why do you need swash settings for the Mini CP at all?
- HappyHarry
18 Jul 2016 19:50 #51843
by HappyHarry
I'm not sure about the mini cp but some of the cheap flybarless fcb's require the tx to do the swash mixing (hisky 100/80 and their wltoys counterparts spring to mind iirc) as they don't do it themselves
- aMax
18 Jul 2016 20:20 - 18 Jul 2016 20:30 #51847
by aMax
Replied by aMax on topic New Firmware V5.0 something wrong of Devo6S
Modell Heli....simple 4 channel setup , no swash mix
plus hold = channel 5
plus pitch = channel 6
plus gyro on channel 7 ( if you want to change something for different flight modes).
Last edit: 18 Jul 2016 20:30 by aMax. Reason: typo
18 Jul 2016 20:20 #51848
AFAIK none of the Walkera FBL CP helis need swash mixing, except the RX2702/2703 receivers.
I don't have a Mini CP, but I do have a Genius CP and a Super CP, and neither of them needs it...
- HappyHarry
18 Jul 2016 20:35 - 18 Jul 2016 20:36 #51849
by HappyHarry
then that will be his problem lol, and though it's not pertinent here i just checked and yeah the fbl100/hcp100/v922 and the fbl80/hcp80/v933 do require ccpm swash mixing in the tx
Last edit: 18 Jul 2016 20:36 by HappyHarry.
19 Jul 2016 00:55 #51862
Replied by mwm on topic New Firmware V5.0 something wrong of Devo6S
I do have a Mini CP (bought it RTF with a Devo 7E so I could try deviationTx on the cheap).
It doesn't need swash mixing.
And best to stay way from channel 7. It'll switch you from heading hold to the undocumented rate mode, which you almost certainly don't want to use. Unless you want a cheap-to-crash not-a-simulator way to practice flying in rate mode.
- Li
19 Jul 2016 11:57 #51887
by Li
Replied by Li on topic New Firmware V5.0 something wrong of Devo6S
Yes, I agree ! firmware V5.0 of Model Heli is without mix of output, very big difference of V4.01 , last year my DEVO 6S firmware V4.01 setting very easy , I did not needed set swash or something it could control my Mini CP and many my small helicopter ……
But update new firmware V5.0 after gave me many trouble !!
- Thomas.Heiss
19 Jul 2016 17:53 - 19 Jul 2016 17:59 #51891
by Thomas.Heiss
Replied by Thomas.Heiss on topic New Firmware V5.0 something wrong of Devo6S
So, does it finally work when you set heli / CCPM mix to NONE for FBL?
Well, as pointed out in several threads, it MIGHT still be required that you need to swap AIL/ELEV Cyclic1/Cyclic2 channels if you work with any of the provided heli templates - using 6CH heli template (even for NONE setting) - might be switched depending on CCPM/FBL.
Quite hard to test all scenarios and write the template that it works for all of them.
Are you using advanced or standard heli mixer GUI?
Just see the other heli threads and open BugTracker tickets (and linked threads)...
Thomas
Thomas
Last edit: 19 Jul 2016 17:59 by Thomas.Heiss.
- MacGyverek
20 Jul 2016 07:56 #51911
by MacGyverek
Replied by MacGyverek on topic New Firmware V5.0 something wrong of Devo6S
What about BugTracker ?? Server is down?? Link not working:
www.deviationtx.com/mantisbt/
- Thomas.Heiss
17 Sep 2016 08:04 - 17 Sep 2016 08:30 #53950
by Thomas.Heiss
Deviation 5.0 as been released:
www.deviationtx.com/forum/6-general-disc...eased?start=60#53953
Heli problem / workaround description including link to new "heli summary analysis developer" thread.
Developer thread includes updated heli templates (working for advanced GUI NONE/FBL+CCPM120, standard GUI NONE/FBL on my side - not or only partly CCPM120)
Thomas
Thomas
Last edit: 17 Sep 2016 08:30 by Thomas.Heiss.
Time to create page: 0.049 seconds
