Nightly builds
- -=Hubi-Dirk=-
I check almost every day to see if a new version is available. What can we do to get an update?
Best regards
Dirk
- propnut
Just to Echo what others have already said, the Nightly builds ceased building in June ? Was this deliberate or has a cron job stopped ?
- -=Hubi-Dirk=-
if it is not possible to get a new version of the nightlies so maybe there is a way to get the last failure free version?
I tried all actual available versions of the nightlies for my Devo 12S from the download section. At all versions i get a black screen while booting.
Best
Dirk
- RSM
- Topic Author
- propnut
I fear otherwise that perhaps this project has been abandoned.
- -=Hubi-Dirk=-
This version works fine and also Voice is present.
Thanks again and best greetings
Dirk
- propnut
- Topic Author
- propnut
- Topic Author
- propnut
ERROR: Target 'en_US' is not in list (devo8 devo10 devo12)
Makefile:290: recipe for target 'filesystem/devo7e/models/model30.ini' failed
make: *** [filesystem/devo7e/models/model30.ini] Error 1
- Topic Author
- propnut
7e (normal and 256), 10 , F7 , F12 (both normal and XMS), T8SGv2 and Plus
Are you building in the Docker image or on a Linux platform. I suspect some of my libraries are incorrect although I did follow the instructions on the ARM environment
- Topic Author
I use very old local Windows build environment (open at 2012.11.09). It can't work with current nightly builds, but work with BRANCH_5.0 and BRANCH_5.X.
www.deviationtx.com/wiki/development/setting_up_build_env
- Topic Author
Reference nightly build Deviation v5.x.x
www.deviationtx.com/forum/builds/8508-re...ild-deviation-v5-x-x
- propnut
- Moeder
BTW, the missing nightlies are due to rom space issues on devo6 platform and we are looking into different solutions to this.
- propnut
- Moeder
- Home
- Nightly builds
