ELRS On T8SG V2
30 Nov 2022 20:17 #78123 by Sh0ck
ELRS On T8SG V2 was created by Sh0ck
Hello everyone! I just got my betafpv micro 2.4 500mW module, and currently trying to use it with my T8SG V2 (non-plus). I have updated the firmware to the latest version and using the crossfire protocol. I'm trying to bind to the built in module on Matek f405 WTE board labeled as DIY 2.4. It seems that after flashing both the TX and RX they bind together for a bit, but then become disconnected and go in wifi mode. It also seems like when I bind the TX and RX for that short amount of time I don't have any link with the module and the transmitter, as if they're not talking to each other. Question is, can you use modern ELRS systems with the T8SG V2 with the new firmware installed?
30 Nov 2022 23:49 #78124 by hexfet
Replied by hexfet on topic ELRS On T8SG V2
Yes, ELRS is supported but the version to use is found under Downloads, Test Builds, [hexfet]nightly_build . Unfortunately the automated nightly builds from github are not working.
Current link is [hexfet]nightly_build but the url will change next time the files are updated.
Time to create page: 0.025 seconds
