Walkera News
16 May 2012 08:37 #305 by FDR
Walkera News was created by FDR
Walkera's news, announcements and fw upgrades...
16 May 2012 08:43 - 17 May 2012 04:59 #306 by FDR
Replied by FDR on topic 2012-05-16 DEVO 8, 8S, 10 fw upgrade
2012-05-16:
New fw upgrades are available for the DEVO 8, 8S and 10.
DEVO 8:
1.It is a must to update both the program and library documents, othersise the radio or the icon won’t work well.
2.Optimized the power supply manage system,decrease uptime power lost.
3.Amend the beep alarm ,there are different tone or time space in different condition.
4.Amend the stop watch stepwidth to 10S,the MIN. setting is 10S,MAX setting is 60 mins.
DEVO 8 100mw fw: v0.8A lib: v0.0.5
DEVO 8 10mw fw: v0.8B lib: v0.0.5
DEVO 8S:
2.Amend the “signal lose” while using the telemetry function of this radio.
3.Optimized the power supply manage system,decrease uptime power lost.
4.Amend the beep alarm ,there are different tone or time space in different condition.
5.Amend the stop watch stepwidth to 10S,the MIN. setting is 10S,MAX setting is 60 mins.
DEVO 8S 100mw fw: v0.8A lib: v0.0.5
DEVO 8S 10mw fw: v0.8B lib: v0.0.5
DEVO 10:
1.Amend the “signal lose” while using the telemetry function of this radio.
3.Add the battery alarm and voltage adjustment function,to protect the usage of 12V battery,when the battery voltage is below 0.4V the alarm will beep , and then power off the radio immediately.(the monitor voltage value of 12V battery would be highly recommended to set above 9.6V; For the dry battery or ni-h battery the monitor voltage value would be recommended above 8.4V )
DEVO 10 100mw fw: v0.5A lib: v0.2
DEVO 10 10mw fw: v0.5B lib: v0.2
Last edit: 17 May 2012 04:59 by FDR.
16 May 2012 22:38 #308 by MatCat
Replied by MatCat on topic Re: 2012-05-16 DEVO 8, 8S, 10 fw upgrade
Any news of whats new?
22 May 2012 08:51 - 22 May 2012 09:13 #338 by FDR
Replied by FDR on topic 2012-05-22 fw update for the Mini CP
Another model fw update available:
Mini CP v1.1
Last edit: 22 May 2012 09:13 by FDR.
22 May 2012 09:22 #340 by FDR
2012-05-22:
New fw upgrades are available for the DEVO 6, 6S, 12 and 12S.
DEVO 6:
Note:
DEVO 6 100mW fw v0.6A lib v0.3
DEVO 6 10mW fw v0.6B lib v0.3
DEVO 6S:
Note:
DEVO 6S 100mW fw v0.6A lib v0.3
DEVO 6S 10mW fw v0.6B lib v0.3
DEVO 12:
Note:
DEVO 12 100mW fw v1.4A lib v1.0.8
DEVO 12 10mW fw v1.4B lib v1.0.8
DEVO 12S:
Note:
5,Amend the stop watch stepwidth to 10S,the MIN. setting is 10S,MAX setting is 60 mins.
DEVO 12S 100mW fw v1.4A lib v1.0.8
DEVO 12S 10mW fw v1.4B lib v1.0.8
27 Jun 2012 11:42 #424 by FDR
2012-06-27:
New version of the Devention Dfuse USB Upgrade Tools v1.5 is available:
1.Adding Support for DEVO-7E program update
2.Can be used to WIN XP/WIN7
10 Jul 2012 07:58 #455 by FDR
Replied by FDR on topic 2012-07-06 fw update for DEVO 10
2012-07-06:
DEVO 10 got a bug fix.
Note:
2.This software upgrade fixes the 0.5A wireless Cowper model data in version 0.5 to 0.5B can not update the model data BUG
DEVO 10 100mW fw v0.6A lib v0.2
DEVO 10 10mW fw v0.6B lib v0.2
27 Feb 2013 09:34 - 27 Feb 2013 09:42 #7129 by FDR
Replied by FDR on topic 2013-02-19 fw update for DEVO 7E
2013-02-19:
DEVO 7E fw v0.1 appeared on the chinese Walkera site.
DEVO 7E 10mW fw v0.1A
Last edit: 27 Feb 2013 09:42 by FDR.
27 Feb 2013 09:38 - 27 Feb 2013 09:43 #7130 by FDR
Replied by FDR on topic 2013-02-27 Dfuse upgrade
2013-02-27:
Devention Dfuse USB Upgrade Tools got new version v1.7, but it is only on the chinese site.
Note:
1.Adding Support for DEVOF4/DEVO F7 program update.
Software update
Download v1.7
Last edit: 27 Feb 2013 09:43 by FDR.
27 Feb 2013 09:46 #7131 by FDR
2013-02-27:
Both the DEVO F4 and F7 firmware updates appeared on the chinese Walkera site, however the download links are wrong.
Note:
Improved fixed ID stability
28 Feb 2013 12:46 #7164 by FDR
FDR wrote: 2013-02-27:
Note:
2013-02-28 They've corrected the links:
DEVO F7 100mW v0.3A
DEVO F4 100mW v0.2A
05 Apr 2013 12:44 #8557 by FDR
DEVO 6/6S:
DEVO 6 100mW v0.7A
DEVO 6 10mW v0.7B
DEVO 7:
1.Amend the Swashplate Mix Control BUG
2.Intall SerialAngel Client upgrade software first.
DEVO 7 100mW v0.5A
DEVO 7 10mW v0.5B
DEVO 7E:
DEVO 7E v0.2
DEVO 8/8S:
DEVO 8 100mW v0.9A
DEVO 8 10mW v0.9B
DEVO 10:
3.Optimization system.
DEVO 10 100mW v0.7A
DEVO 10 10mW v0.7B
DEVO 12/12S:
DEVO 12 100mW v1.5A
DEVO 12 10mW v1.5B
18 Oct 2013 04:05 #14744 by FDR
Replied by FDR on topic 2013-10-14 DfuSe Upgrade v2.0
2013-10-14:
Devention Dfuse USB Upgrade Tools got new version v2.0.
Note:
"V2.0 improved used on Windows 7,and can be applied to Windows 8."
Download v2.0
08 Nov 2013 05:21 #15437 by FDR
Replied by FDR on topic New DEVO F7 DS
Walkera introduced a new tx to the DEVO line the DEVO F7 DS with 2.4GHz frequency hopping synchronized digital AV transmittion:
www.walkera.com/en/showgoods.php?id=2550
03 Dec 2013 14:47 #16231 by FDR
Replied by FDR on topic New DEVO F4 DS
...and the same with 4 channels the DEVO F4 DS:
www.walkera.com/en/showgoods.php?id=2551
Time to create page: 0.048 seconds
