WLToys V922
- rototophe
04 Dec 2012 21:46 - 05 Dec 2012 01:03 #3640
by rototophe
WLToys V922 was created by rototophe
In a few days will come out the new V922 collective pitch 100 size micro helicopter by WL Toys soon to be followed by a smaller 80 size version sometime in January.
www.banggood.com/Wholesale-Wltoys-V922-2...ter-Rtf-p-55862.html
It is actually a clone of the HiSky FBL100
www.banggood.com/Wholesale-Hisky-Fbl100-...icopter-p-48795.html
And of the Hobbyking Turnigy FL100
www.hobbyking.com/hobbyking/store/uh_vie....asp?idProduct=24470
Thread in RCGROUP on this heli:
www.rcgroups.com/forums/showthread.php?t=1732214
Sadly enough it is confirm that WL Toys is dropping Flysky support and that this heli will not be Flysky compatible (as some of the newer V911 apparently btw),
It also seems that the radio that will be shipped with the heli will not even have adjustable curves, so it will have one preset set 3D mode, that's it. Kinda sad ...
Ok I suppose it's pretty obvious where I'm going with this ...
Call Deviation to the rescue!
It's hard to have definitive info on the heli quite yet but it looks like all 3 versions are compatible protocol-wise and that it uses NRF24.
Here is a couple pictures of the Rx:
Looks like a couple promising helis at a reasonable price, shame it has no Flysky compatibility and a very limited crappy radio shipped with it.
PB, do you think this something you'd consider investigating when it becomes widely available?
Last edit: 05 Dec 2012 01:03 by rototophe.
05 Dec 2012 02:39 #3644
Replied by PhracturedBlue on topic WLToys V922
Sure. I'll likely order one when they are actually in stock. I learned my lesson with banggood. I'll only order in-stock parts. It will of course require a new module to work. Whether it can be done at all depends on the protocol, and there is no way to know anything about it until we can tap into the spi bus and see what is going on.
- NT72
11 May 2013 15:17 #9847
by NT72
Replied by NT72 on topic WLToys V922
Is it possible to connect the V922 with the Devo8?
Thanks for your help.
11 May 2013 15:40 #9851
Not yet. This is a difficult one to support due to the chip used. victzh is working on a 'Q-BOT' which may use the same protocol as the v922. If so, then that will allow us to add proper support.
- NT72
12 May 2013 00:52 #9883
by NT72
Thanks PB!
is this a hardware or a software problem, or both???
Do I need modifying the transmitter?
where should I look to be on the latest state?
Thanks NT
Thanks NT
12 May 2013 02:04 #9884
You will need a new hardware module, but it also requires new software. The hardware itself is not too hard to install, but learning enough to write the software will be quite challenging. There is no 'best' place to check for status. When its ready it will be posted.
- NT72
12 May 2013 16:08 #9898
by NT72
Is it the HT8 adapter?
Okay, then I will wait.
Thanks PB.
Thanks PB.
Time to create page: 1.590 seconds
- WLToys V922
