Ch1 is 0%
- N4JC
- Topic Author
01 Jan 2013 07:21 #4457
by N4JC
Ch1 is 0% was created by N4JC
Hi, I have the following model file for my Canary SQ glider (this was completely built from the Tx), when I load the model or turn on the Tx with this as the default model the Tx shows this:
Ch1 is 0%, safe value = -100% [Ok]
I press Ent to dismiss the message, and all seems fine.
This is a simple 2 channels rudder and elevator setup.
name=Canary SQt1
type=plane
[radio]
protocol=DSM2
num_channels=7
tx_power=30mW
[channel3]
subtrim=400
scalar-=0
template=expo_dr
[mixer]
src=ELE
dest=Ch3
curvetype=9point
points=-55,-28,-15,-7,0,11,28,52,100
[channel4]
reverse=1
subtrim=412
scalar-=0
template=expo_dr
[mixer]
src=AIL
dest=Ch4
curvetype=9point
points=-55,-27,-14,-7,0,10,25,49,100
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=2
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=3
value=1
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=2
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=2
value=1
[timer1]
src=RUD DR
[timer2]
type=countdown
time=2700
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box2=Timer1
box7=Ch3
box8=Ch4
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=AIL DR
toggle3=RUD DR
tglico3=2
toggle4=GEAR
tglico4=4
quickpage1=Telemetry monitor
name=Canary SQt1
type=plane
[radio]
protocol=DSM2
num_channels=7
tx_power=30mW
[channel3]
subtrim=400
scalar-=0
template=expo_dr
[mixer]
src=ELE
dest=Ch3
curvetype=9point
[channel4]
reverse=1
subtrim=412
scalar-=0
template=expo_dr
[mixer]
src=AIL
dest=Ch4
curvetype=9point
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=2
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=3
value=1
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=2
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=2
value=1
[timer1]
src=RUD DR
[timer2]
type=countdown
time=2700
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box2=Timer1
box7=Ch3
box8=Ch4
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=AIL DR
toggle3=RUD DR
tglico3=2
toggle4=GEAR
tglico4=4
- N4JC
- Topic Author
01 Jan 2013 07:49 #4459
by N4JC
Replied by N4JC on topic Ch1 is 0%
I worked around this problem by adding channel 1.
The Mixer for 1-THR was set to NONE, changed it to Simple.
Should I file this as a bug?
01 Jan 2013 10:33 #4464
Replied by FDR on topic Ch1 is 0%
No, it's actually a feature, which won't start if throttle is on.
However you don't have throttle on a glider, so you can simply delete the following from the file:
We don't have UI for this yet...
N4JC wrote: [safety]
Auto=min
- N4JC
- Topic Author
01 Jan 2013 17:32 #4481
by N4JC
Ah, that makes sense, thanks for the reply.
Time to create page: 0.030 seconds
- Home
- General
- General Discussions
- Ch1 is 0%
