Just ordered my Devo 10, hints and tips?
- wussie
- stevecox
- Keep swinging
Adelaide
- wussie
- domcars0
Read the full documentationwussie wrote: Anything else I should read?
www.deviationtx.com/repository/Documentation/
You will also learn how to use the emulator.
- sbstnp
wussie wrote: ... can I use the emulator to create my own that I can transfer over once I have the radio in hand?
Yes you can. I will also suggest (if you are a beginner) you get familiarized with general concepts like:
1. Channels
2. Channel order depending on protocol.
3. Expo
4. D/R
Devo 10 + 4in1
FrSky Taranis + TBS Crossfire
- JFS737
Download some model configs and have them ready... maybe you could study them and adjust them in the emulator, but I don't know how that works. Also Download some Icons (for the 10) or you could read the instructions on how to make icons and have some ready when the TX shows up.
The usb tab on the back where you attach the cable is stiff... it needs to be pulled OUT away from the TX towards you about 1/4 inch... it kind of pops when it's done right. Takes a little elbow grease.
I got 2 LIFEPO4 3s batteries at about 2000mah and soldered a new connection to the radio to take them. They last a long time and charge very quickly. The voltage curve is pretty flat in the useable area and I set my low voltage TX alarm at 9.45V. Usually gives me about 1500mah back into the battery.
I really love mine and deviation... I'm on hold at the moement due to some technical issues. Enjoy.
John
- wussie
Edit: Any chance you can link me to those batteries? I bought some NiMH for my radio, but some LiFe might be nice too. I'm sure I can pick up the correct connectors at my LHS. Thanks!
- JFS737
Here is the battery... www.hobbyking.com/hobbyking/store/uh_vie....asp?idProduct=14076
Any LIFEPO4 with similar measurements and 3S would work. You may have to solder some. Good luck and have fun.
- stevecox
- Keep swinging
Adelaide
- JFS737
Regards,
John
- Just ordered my Devo 10, hints and tips?
