Devo 10 Illuminated Logo with a red LED
- sbstnp
Well, today I decided to mount my own. I only had green and red leds around and I decided on red since it looks better with the sticks and writing. The LED is a 5mm, I put a resistor in series and connected it to 3.3V.
There is enough space to mount around 3x5mm LEDs inside. Sorry, I didn't took pictures while mounting it.
EDIT:
Very important: I sanded the LED before mounting just to have nicely diffused light.
Devo 10 + 4in1
FrSky Taranis + TBS Crossfire
- domcars0
Thank's
- stevecox
- Keep swinging
Man I lurve Deviation & the people
Adelaide
- Scream
well done bro! Pic added to heliporn library
Slightly related... I Was thinking team Deviation should make a sticker that's says Deviation to go right above where you've mounted your led... It would fit the theme too if only the "IA" and "DEVO 10" was transparent to let the LED through
A kit, with the LED and the sticker would be a great fund raiser for a well deserved development team (but that's a whole separate topic!).
Next time you take off her pants off (DEVO 10), please take a pic or 4 of the mod, I'd love to add this too!
Thanks for sharing!
-=S=-
Cheers!
-=S=-
- evo165
I am using 3s lipo battery... Not sure if i can do the LED mod and connect it directly on the on/off switch.
Please advice sir...
- sbstnp
Devo 10 + 4in1
- misterpepper
- evo165
I try open up my Devo 10 last night. I need to remove the middle small board in order for me to access the "Devo 10"... Man, There are many wires i really need to un-plug off from the small board.
- sbstnp
Thos wires you see are clearly labeled and mistakes should not be possible. But, before I disconnect anything new to me I take a picture. Simple but very effective way of remembering the initial state of what I'm gonna disassemble.
evo165 wrote: Please tell me which additional modules 3.3v you use? Or which is the exact parts that you tap the the wiring to?
Devo 10 + 4in1
- SadSack
- Timmz32
- sbstnp
Devo 10 + 4in1
- Devo 10 Illuminated Logo with a red LED
