How to setup double command?
- Xermalk
Is there a guide somewhere on how to setup double command?
I have a friend that wants to try to fly my mini quad and heicopter, and i have a Devo 10 and Devo7E capable of flying it.
I would love if someone had a template for Walkera double command, and DSM2 double command.
I skimmed the manual but couldn't seem to find the section regarding double command/buddy boxing.
With the actual nightly builds (not sure if already implemented in the main stream 3.0.0) there is an option for PPM. On the trainee's tx you set the protocol to PPM out, on the trainer's tx you set PPM in to "Channel", assign the channels (1:1 if you use the same model.ini) and define a trainer switch (don't know which way it works: active means trainee or trainer has control?).
There is another thread about PPM input where you can find further information: http://www.deviationtx.com/forum/7-development/1323-usb-hid-joystick-ppm-in-program?start=100#10845
- dawsonmobley
rbe2012 wrote: I assume you mean a trainer mode?
Am I correct in assuming both tx's need to have deviation firmware installed to buddybox? Been waiting for this capability to be added, I even added a secondary micro switch to the front right of my 8s back before I started using deviation for quick switching so I'm hoping I will be able to use it again as well. I have a spare 7e I hope to use as the trainer tx since it looks liek deviation is available for it now as well?
No, you don't have to, but it's indeed more simple if both transmitters have the same config...dawsonmobley wrote: Am I correct in assuming both tx's need to have deviation firmware installed to buddybox?
- Xermalk
For some reason it was sending 0 -200 something on the channel instead of -100 to 100. And some channels on the "master" tx seemed to stop working as they should.
Ill post the model files when i wake up tomorrow.
- Xermalk
model1.ini is the master file and model7.ini is the slave one.
- Xermalk
What? really it was set to 7 on the field. The 7E was controlling all the channels, but at very odd values.rbe2012 wrote: In model1.ini NUM_CHANNELS for PPM in is set to 1 - should be 6 to controll all six channels with both tx...
Edit: I just double checked the tx. There is no way to set number of channels when you select ppm in: Channel in model setup. All i can do is assign ppm 1-8 to specific tx channels.
I will try your config later in the evening and report back.
I have tested the trainer mode again. It is quite useful to have two identically configured models (I did not have this and wondered about pitch jumps when switching until I have made them the same; easier is to copy the model config from one tx to the other). On the trainee's tx you change the protocol to PPM, at least 6 channels, remove the unique id and select "re-init".
On the trainer's rx go into the model config and change "PPM in" to "channel" and configure the channels. Since you have copied the model, the input-to-output channel mapping is 1:1 (in your config ch1 and 2 are swapped). Then select a switch to activate the trainer mode (you have used GEAR0). As long as the switch is in the selected position, the trainee controls your bird, if not (GEAR1) you do.
So nearly everything looks fine in your config besides the "num_channels=1" thing. But I am not sure if this is important - in the emulator where I configured a model similar I ended with "num_channels=0"...
I have seen you moved the center value from standard 1500 to 1100 (centerpw=1100)- this might affect the values because the trainer tx expects them at 1500. I am not sure how great this effect is but from my guess it should be the same at trainee's output and trainer's input.
I actually don't have my tx in my hands so I can't copy my working config. But believe me: my daughter has flown her first collective pitch Blade Nano today.
- Xermalk
Im in no hurry as the weather is crap atm.
- dawsonmobley
Also, Can I transfer a ini from my 8s directly to the 7e without any changes? (aside from the ones you mentioned that is)
I will probably post them in the afternoon.
For now I have created two simple configs where I have configured what is necessary (but can actually test them only in the emulator).
These are for Devo8. I took new models, loaded the 6ch-heli-template and configured PPM:
I had my wife looking into the config of the trainee's model (not easy to get her doing this...) and there is also a value of 1100 (I didn't change it). So this might be correct. I'll do a little bit research on this...
Dawsonmobley, you wrote
No, it is not there until you use PPM (as output protocol or as input). I have configured everything with the gui.Does the "ppm in" section in the ini have to be added and edited outside of the tx gui? That section is not in any of my config files.
Yes, you can. Some parts will not work correctly: the switches and the gui.Also, Can I transfer a ini from my 8s directly to the 7e without any changes? (aside from the ones you mentioned that is)
Since the 7e has less switches not every function can be controlled as it is in Devo8. I can hardly test this but I am quite sure that there is some switch mapping (e.g. all AIL/ELE/RUDD DR map to the DR switch, GEAR is mapped to HOLD).
The gui is not transferable, but the model comes up with the default screen so you don't have to care about this.
I have transferred the configs from above for Devo7e emulator:_here is how they changed:
dawsonmobley wrote: Does the "ppm in" section in the ini have to be added and edited outside of the tx gui? That section is not in any of my config files.
It's not implemented in v3.00. You have to use Nightly builds for 'PPM In' feature.
- dawsonmobley
I installed the nightly build on both tx's and following the instructions here I was able to change control back and forth using the gear switch but I had a few other questions now.
Before I knew about deviation I used walkeras buddybox setup which switched back and forth using the little +/_ momentary switch to the left of the mix switch on the 8s. I wanted the buddybox switch somewhere I could keep a finger on it without taking my thumbs off the sticks or looking down so I added a micro momentary switch to the front right corner of the 8s and wired it to the above mentioned switch which is walkeras default buddybox switch.... and it worked great, heres the rcgroups thread showing what I did . Is there anyway I can change the buddybox switch in deviation to use that little momentary switch for fliping from trainer to trainee? I honestly don't even know for sure what that switch is used for normally or how to setup to use it or what it's called in the model config.
My other question is about disabling channels. I found it useful to disable the trainees ability to control the yaw and throttle (controll of those channels remained on the trainer tx) so they could focus on ele and ail control. Is it possible to do this with deviation currently and if so, how?
- dawsonmobley
FDR wrote: You can configure a trim to be a toggle switch for a virtual channel, and use that virtual channel as the switch for the trainer mode...
is there instructions on doing that somewhere...I picked vir1, simple, and under source it lists all the other switches on the tx but no option to select a trim switch as the source?
- Mario Gosselin
It is possible to make a trainer with devo10(master)deviation 3.0.0 and wk-2801 pro
- How to setup double command?
