rx2703h-d cancel fixedID
- wesa-76
21 Dec 2013 15:17 - 21 Dec 2013 15:19 #16887
by wesa-76
rx2703h-d cancel fixedID was created by wesa-76
Is there any solutions to my rx2703h-d. problem is canceling fixed ID. Bind plug does nothing and I dont know pin number. This update should solve the problem but it doesn`t
Last edit: 21 Dec 2013 15:19 by wesa-76. Reason: failed attachment
21 Dec 2013 15:46 #16889
Replied by PhracturedBlue on topic rx2703h-d cancel fixedID
I moved this post to the proper section.
If you aren't aware, this is not an official Walkera forum. I don't know much about this Rx, but generally it can be difficult to get some Walkera Rx to unbind. usually trying the bind-plug in every channel and trying shorting both to power and ground (but not at the same time!) will eventually make it work though.
- Hexperience
21 Dec 2013 19:58 #16900
by Hexperience
Replied by Hexperience on topic rx2703h-d cancel fixedID
Bind plug goes in the elevator channel on that one.
Put the plug in then power it up. It will flash slowly. Then remove power and the bind plug. Power it up again and bind with or without an id.
- Rollmops67
31 Jan 2014 22:34 - 31 Jan 2014 22:35 #19534
by Rollmops67
I saw this post only now, I don't know if it will still be usefull.
Yes there is a firmware problem on the rx2703h-d wich makes unbinding impossible.
Here is a link wich explains how to update (you need an adapter for that) :
www.rcgroups.com/forums/showpost.php?p=25083881&postcount=1061
The firmware (it's for the V450D01 but it's the same for the V450D03) can be downloaded here :
walkera.com/en/progoods.php?id=445&type=fly
And you will also need the program for upgrading wich you can find here :
walkera.com/en/updater.php
Good luck !
Roland
Replied by Rollmops67 on topic rx2703h-d cancel fixedID
Hello Wesa.wesa-76 wrote: Is there any solutions to my rx2703h-d. problem is canceling fixed ID. Bind plug does nothing and I dont know pin number. This update should solve the problem but it doesn`t
Good luck !
Roland
Last edit: 31 Jan 2014 22:35 by Rollmops67.
Time to create page: 0.103 seconds
- rx2703h-d cancel fixedID
