Upgrade the DEVO 7E
30 Sep 2015 17:16 - 30 Sep 2015 17:20 #38278 by cctsao1008
Upgrade the DEVO 7E was created by cctsao1008
This is my DEVO 7E with...
STM32F103RET6 512kB Flash, 64kB RAM 64pin package
SST25VF032B 4MB SPI NOR Flash
I am going to add a 915Mhz 3DR radio inside the devo7e and trying to add the mavlink protocol to talk it and show some useful informations on the LCD.
Last edit: 30 Sep 2015 17:20 by cctsao1008.
02 Oct 2015 09:53 - 02 Oct 2015 10:24 #38346 by cctsao1008
Replied by cctsao1008 on topic Upgrade the DEVO 7E
Devo 7E Super
Last edit: 02 Oct 2015 10:24 by cctsao1008.
02 Oct 2015 10:24 #38347 by Durete
Replied by Durete on topic Upgrade the DEVO 7E
Nice!
Good job :)
02 Oct 2015 11:04 #38350 by Fernandez
Replied by Fernandez on topic Upgrade the DEVO 7E
I am interested and happy to do same with my devo 7e.....
Could you explain the benefits of the new mcu and what firmware should we run will it stay compatible? Will there be builds for it to use the CPU?
Can you also hook up the 2 extra analog pots ? See here: www.deviationtx.com/forum/6-general-disc...evo7e?start=40#34661
Instead of 3dm link, have you seen; UltraLRS link, also quite interesting, very good range is cheap, low frequency uhf for better penetration objects and can transmit control and telemetry signal.
www.rcgroups.com/forums/showthread.php?t=2037442
02 Oct 2015 12:59 - 02 Oct 2015 13:00 #38351 by Cereal_Killer
Replied by Cereal_Killer on topic Upgrade the DEVO 7E
Wow, the integrated 3DR w/ mavlink sounds amazing.
I am in no way trying to downplay your existing goals, they sound awesome and are definitely already very ambitious; but just imagine if you could work in a USB output to display the received mavlink data on a USB-OTG phone /tablet (think dji style). The HW already exists...
Edit: or skip the USB output and do it via BT!!
Last edit: 02 Oct 2015 13:00 by Cereal_Killer.
08 Oct 2015 16:58 #38594 by cctsao1008
I have add the FreeRTOS in the code and the RTOS runs well.
08 Oct 2015 17:30 - 08 Oct 2015 17:30 #38597 by cctsao1008
Run the FreeRTOS on my devo7e.
Test code :
freertos_devo7e.zip
Last edit: 08 Oct 2015 17:30 by cctsao1008.
09 Oct 2015 06:53 - 09 Oct 2015 06:54 #38619 by mwm
Replied by mwm on topic Upgrade the DEVO 7E
Cool, but why FreeRTOS? After evaluating them, I settled on ChibiOS, as I like that it has three flavors (full-blown RTOS, minimal RTOS, and no RTOS) that run on top of the same hardware abstraction layer.
And more importantly, are you planning on trying to port the devo code to FreeRTOS? I've thought about that, but figure it probably won't fit on a stock 7E, so won't make it into Deviation. But that would just add fuel to the "we should fork Deviation to 7e and non-7e forks" fire.
Last edit: 09 Oct 2015 06:54 by mwm.
11 Oct 2015 19:24 #38745 by Richard96816
Replied by Richard96816 on topic Upgrade the DEVO 7E
Very nice!
17 Nov 2015 14:37 #40151 by Fernandez
I follow with interest any progress here?
Time to create page: 0.045 seconds
