Arming Devo 7e to naze32
- PREACHER
05 Mar 2016 21:42 #44164
by PREACHER
Arming Devo 7e to naze32 was created by PREACHER
So I'm a noob for sure on this one.
Here's the issue...
I do no know how to arm my Devo 7e with upgraded firmware to the Naze 32.
I am binding to a Devo rx701 and using clean flight.
Has anyone done this? If so can you contact me directly?
8134421151 and my name is Greg!
Thanks so much!
Here's the issue...
Thanks so much!
- PREACHER
06 Mar 2016 03:14 - 06 Mar 2016 03:15 #44171
by PREACHER
Replied by PREACHER on topic Arming Devo 7e to naze32
Ok so I sorta figured out what I needed to do which is change my throttle values on both the TX and clean flight to match. But I can't seem to find a happy medium.
Can anyone help me with this?
Again I'm using...
Devo 7e
Devo rx701
Naze32
Clean flight configurater
Again I'm using...
Devo 7e
Devo rx701
Naze32
Last edit: 06 Mar 2016 03:15 by PREACHER.
- grnd flyr
06 Mar 2016 03:51 #44173
by grnd flyr
Replied by grnd flyr on topic Arming Devo 7e to naze32
Heya Preacher,
Not sure I understand the question but a quick search gave a couple links to hopefully help you get going in the right direction...:
How to: Cleanflight & Deviation, 4 flight modes on a single channel!
TOPIC: Configuring Devo RX601 with CC3D and cleanflight
www.deviationtx.com/forum/6-general-disc...cc3d-and-cleanflight
- PREACHER
06 Mar 2016 14:28 #44192
by PREACHER
I just need help figuring out how to arm and disarm my quad with a simple stick command or switch. I believe it's specifically done through my devo7e and clean flight. But I def need help
- grnd flyr
06 Mar 2016 15:02 #44193
by grnd flyr
Why didn't you say so then...
jk
I haven't done this with my 7E yet but have with the Taranis (stock, out of the box, simply hold throttle left til it beeps to arm, then hold throttle right til it beeps to disarm)... check this vid out to set it up with a switch:
Cleanflight (NAZE32) Disarm and Arm with Transmitter Switch Tutorialby Johnathan Smith
- aMax
06 Mar 2016 15:34 - 06 Mar 2016 16:15 #44194
by aMax
Replied by aMax on topic Arming Devo 7e to naze32
Check your settings on the CF configurator..
throttle setup, transmitter tab, failsafe and cli setttings .
The failsafe will be ignored within 5 seconds after power on and after that time with no proper setup, you will be no more able to arm.
Notice, it's mostly an user error and not the tx setup.
Did you calibrate the esc within the motor tab or with your transmitter? Doing that with the configurator for all at once is recommended.
Google and YT help on that.
... and www.rcgroups.com/forums/showthread.php?t=2249574
..and this is not the only topic there.
www.rcgroups.com/forums/showthread.php?t=1981397
www.rcgroups.com/forums/showthread.php?t=2320471&page=13
EDIT:
So start reading because it will take some weeks even for the basics. Mostly all quad fliers have to go through this first.
It is no more a toy with simply downloading an ini file and fly.
EDIT2:
I think this will help you too.
The guy has many technical videos there. (Joshua Bardwell)
Calibrating ESCs with Cleanflight and BLHeliSuite
m2c
EDIT:
EDIT2:
m2c
Last edit: 06 Mar 2016 16:15 by aMax.
Time to create page: 1.602 seconds
- Arming Devo 7e to naze32
