DIY 433mhz long range system
- Cereal_Killer
This is a replacement board for the [no longer available] OrangeRx LRS modules. Running the HopeRF RFM23BP module at 6V this board is a full 1W transceiver capable of accepting PPM input or having a PPM output (via same pin depending on which FW you load: RX vs TX). Also a fully transparent serial port is also available so the same system can pass RC commands from ground to aircraft at the same time as passing 2-way data comms' for telemetry / GCS software (such as MAVlink control). The board is designed with Ultimate LRS in mind however as it's an exact clone of the Orange module it will also run OpenLRS NG (which BTW I'm looking more into now as it's directly compatable with Taranis unlike ULRS)
The board accepts up to 16V in (4S) and can actually be ran on up to 40V with one slight change (a trace cut and an air-wire). There is also a FDTI compatible header at the top (same thing as the serial port on the side but w/o the resistors in-line to facilitate easier FW flashing with an FDTI).
All components are labeled along with their values except for C4 and C5 (which one, are not actually required and two, will need some testing to decide on exact specs) please see the LM317 datasheet for official TI recommendations. R13 is also unmarked, its a protection resistor for the switch, probably 100-500ohms is good
V1.01 available for order on OSHpark TESTED WORKING
FlipFlap's site ITluxembourg
- Cereal_Killer
Pair of Hope RFM23BP modules $16
LM317-N SOT223 package 20pcs $6
For antenna I've build a Moxon square on a piece of coroplast following this tutorial and will be using monopoles on the receivers. If you're not down to DIY your own antenna VAS offers a very nice Moxon for only about $35 or you can get decent performance from an ebay monopole for say a BaoFeng radio, just make sure you get the correct port for the connector you use to build it.
Dont forget all your passives, I didnt list any cause I didnt need to buy any cause I had it all on hand. The pads are technically 0805 size but I use passives from the SparkFun eagle library which is known to be very large, almost oversized (I regularly use 0603 size pads for 0805 parts cause the sparkfun 0805 pads are so large but I wanted to make it a tad easier for others to solder)
- Nitro_123
Just wondering, any possibilities of SBUS output ?
- Cereal_Killer
I think my biggest question is who here can do the protocol work to use the HopeRF module direct in devo? It is SPI controlled after all!
- Fernandez
However I do not anymore want to use ppm in my tx. Added Latency and jitters and why should we deviation direct digital is the future!
If the ULRS project is documented and open source, I hope that some master coders as guys like Goebish, could have a look at and deviate it, so we can hook up a RFM/hoperf module over SPI in our DEVO's.
The RX side we could use the SBUS, or servoboard over I2C, basically the Ultimate LRS design, or your board.
I am happy to be part of testing, as I have two of the 433 orange modules here, but not yet used them yet.
- HappyHarry
- Cereal_Killer
- HappyHarry
- Macklemore
- victzh
- Cereal_Killer
I don't. Flipflap keeps his code closed source and he alone is responsible for it. He has said recently he envisions future development moving over to teensy (and future modules beige based on it) however promises sbus output to be the final "big thing" for the 328p based modules (diy and OrangeRx/ other supported OEMs)victzh wrote: How do you plan to handle SBUS output...
You don't have to invert it, there are a few diy receivers (2.4 I believe) that have non-inverted sbus outputs, that's why the CLI option [in cleanflight] to turn the inverter off exists.
All my parts are ordered for 6 modules, my only question now; when will devo be modified to take the rfm23bp module so there's no need for the ground side ULRS transceiver and we have native telemetey w/ RSSI?
- Elmtree
Anyways, just expressing my interest in this project
- HappyHarry
- Cereal_Killer
HappyHarry wrote: also could you write a shopping list for the passives?
All 0805 (note I had 0603 470 resistors and plan to use those, they'll be small on the pads but do fit on the package pads I used)
Resistors
220
470
1k
1k8
2k2
3k3
10k
CAPS
150nf (that's 0.15uf)
1uf
Regulator
LM317D (SOT223 package, I got a 20ct pack from ebay for ~$6).
If you plan to hook anything up to i2c (direct at arduino pins) you'll either need to ensure your device has pull-up resistors on board or you'll need to add your own (there are no pads but plenty of space to do so). I2c devices include the Adafruit 16 servo breakout board (draws LOTS of power and will need it's own UBEC for 5v) [air side] or a small OLED display to show RSSI [ground side]. A 2-line LCD [ground side] is in the works too but currently only shows debug data (OLED doesn't need extra power, can run off arduino on-board 5v vreg but ALL it displays is RSSI)
Also, tho it's confirmed not needed (partly cause of how close I put the vreg to the HRF input) I'm likely going to add a decoupling cap for the output of the LM317, that's a small (don't know the package name) tantalum cap ~1-4uf. Didn't order them cause those are one of the parts I always make sure to harvest off old deal electronics and have a million.
I'm still waiting on my boards, if you want to wait till I receive and build them that'll probably be another week and a half or so...
- HappyHarry
- xfce
the big problem is, if i use high power level such as 100mW, when the antenna close to LCD, the menu will go to be mass, seems the RF EMI cause the firmware 's buttonscan function detect key press, and when use low power or be away, all OK.
Is it possible to improve the firmware to get rid of the RF EMI
- Cereal_Killer
- HappyHarry
- Fernandez
PPM days are over, full digital link is what we need and it is the power of deviation.
But Cereal on your work, nice job clean and compact long range RX !
- Cereal_Killer
If someone here was up for the job of protocol upkeep I really think I could get Ben (flipflap) to atleast provide some basic documentation, atleast to us, so the protocol wouldn't have to be reversed...
Anyone down for a new job?
- DIY 433mhz long range system
