Deviation 5.0 - can't change channels
- LITE
18 Jun 2016 16:25 - 18 Jun 2016 16:32 #50779
by LITE
Deviation 5.0 - can't change channels was created by LITE
Welcome!
I have problem with my Devo10, Deviation 5.0 software.
I tried setup Deviation 5.0 to work with Walkera 4F200 heli with Walkera RX2612V receiver.
Channel "Aileron" is replaced with "Elevator" channel - how to setup it correctly in "Standard GUI"?
Next thing - in "standard GUI" I can't change reverse of the channels - why?
Best Regards
LITE
Best Regards
LITE
Last edit: 18 Jun 2016 16:32 by LITE.
18 Jun 2016 20:04 - 18 Jun 2016 20:05 #50782
Replied by mwm on topic Deviation 5.0 - can't change channels
The general answer is "The Standard GUI sucks because none of the developers use it, and nobody has stepped up to do maintenance on it." Sorry 'bout that.
That the channels are reversed is a bug that was probably introduced when a related bug in the template handling was fixed (just a guess, mind you). People have reported that it's been fixed by using a "wrong" swash setting.
There's a "Reverse" menu that should let you reverse all the channels. Unless that's not what you mean by "Reverse the channels". In which case you might try clarifying things, but see the first paragraph.
Last edit: 18 Jun 2016 20:05 by mwm.
- LITE
19 Jun 2016 18:44 #50814
by LITE
Replied by LITE on topic Deviation 5.0 - can't change channels
Thanks for reply!
Next questions:
- how to setup Devo 10 as joystick?
- is possible to use Devo 10 as 12 channel tx with 12 channel Walkera RX1202?
Best Regards
LITE
Next questions:
Best Regards
LITE
- HappyHarry
19 Jun 2016 20:18 #50819
by HappyHarry
Replied by HappyHarry on topic Deviation 5.0 - can't change channels
try setting the swash type to 120x,
how do you mean joystick?
yes it will work as a 12ch tx with the 12ch rx
- LITE
19 Jun 2016 20:44 #50821
by LITE
I can't setup Devo 10+Deviation 5.0 with USB dongle for RC simulator:(
- HappyHarry
19 Jun 2016 21:02 #50823
by HappyHarry
ahh ok, yes you need to plug the usb dongle into the trainer port on the devo10 and then set the protocol to ppm
- Thomas.Heiss
28 Aug 2016 11:28 #53188
by Thomas.Heiss
Replied by Thomas.Heiss on topic Deviation 5.0 - can't change channels
Time to create page: 0.027 seconds
- Deviation 5.0 - can't change channels
