Jumper T8SG binding with an AC800 tx
22 Nov 2017 14:56 #66055 by rsh78ph
Jumper T8SG binding with an AC800 tx was created by rsh78ph
Hi, I am able to bind the Jumper T8SG with an AC800 D8r Frsky rx. This is usually used on micro drones like the tiny 6/7.
My issue is that the there is no stick movement in the channel monitor of Betaflight when I am trying to configure the TX.
Anyone successful in having this combo work?
22 Nov 2017 15:14 #66056 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG binding with an AC800 tx
I don't see any good feedback about that receiver.
www.rcgroups.com/forums/showthread.php?2...-0-8g-any-good/page2
22 Nov 2017 19:31 - 22 Nov 2017 19:31 #66070 by aMax
Replied by aMax on topic Jumper T8SG binding with an AC800 tx
Very less information...
1 CPPM or SBus?
If you use Sbus, check via Betaflight CLI if the signal on uart needs to be inverted or not,.If you use a F4 on the FC,
check if you are on right uart ( F4 donĀ“t have uarts that can be inverted, so there will be a hardware solution , but only
for ONE uart)
If nothing helps >>>> trash can.
Read on here ..
www.rcgroups.com/forums/showthread.php?2...-FrSky-TX-RX-Modules
Topic "LIST OF RECOMMENDED RX"
Last edit: 22 Nov 2017 19:31 by aMax.
25 Nov 2017 00:14 #66146 by rsh78ph
Replied by rsh78ph on topic Jumper T8SG binding with an AC800 tx
Tried it both in Sbus and PPM but still the same results. Binded it with my Taranis and it had no problems.
Would rather use the small form factor of the Jumper.
I have tons of this AC800 as I have several micro quads running on them as it came with this crappy receiver (drop outs)
If still with issues, will get and try the Frsky XM+ or change to Flysky micro rx.
25 Nov 2017 11:10 - 25 Nov 2017 11:43 #66158 by aMax
You are reporting different things, first, no output to the flight controller and now drop outs...?
Check the center frequence.. Did you try to fine tune your transmitter for this receiver?
Edit:
If these drop outs only happen when the micro is close to you, keep some more distance
to it,.because there is no other solution but a different rx firmware that takes care for
this issue ( signal swamping).
Last edit: 25 Nov 2017 11:43 by aMax. Reason: edit
15 Feb 2021 10:16 #77250 by William4170
Replied by William4170 on topic Jumper T8SG binding with an AC800 tx
Hi, my t8sg wont bind to r-xsr. When i power the rx holding the bind button. Rx shows all 3 steady lights. I use frskyX in my tx to bind while still holding bind button on my rx but still no joy.
Tried both fcc and eu mode on fraskyX protocol.
I reboot the quad without holding it goes into blue steady, red slow flashing. Attempt bind also no joy.
