New modules?
- Seven5555
- Topic Author
Thanks in advance. this is such a great project, I hope it's still going.
- Seven5555
- Topic Author
Does anyone know where all the downloads are?
I wish I knew that this before I bought this. This place was booming with life a few years ago.
- -=Hubi-Dirk=-
Latest builds are under the link "[hexfet]nightly_build" on the Test Builds page . I'd give a direct link but it changes with every build. Which doesn't happen often these days.
- Seven5555
- Topic Author
- rc manic
I'm still hanging on with Deviation and old hardware. It does everything I need now. But I can't code and may have to eventually move on.
- Seven5555
- Topic Author
I put the memory in and a new 4n1. I have had trouble getting things going, I have been able to troubleshoot all the problems I've had with the info here but I'm stuck i get "Missing Modules: MultiMod" error. I've been messing with the hareware.ini but more errors..... I keep searching but have found no solution.
So, is this F12e useless for the Open Tx and Eagle Tx that was mentioned?
- ethr
Seven5555 wrote: Thanks for letting me know and thank you very much hexfet for keeping a pulse in this place.
Hello, check connections and hardware.ini file configuration, multiple times. Yesterday I flashed my devo again.. and did a silly mistake. It took me quite a lot, to figure it out. Of course it would be easier, if I copied my hardware.ini file in the first place
You can not install Open Tx or Edge Tx, but you could hook up an ELRS module.. it is brilliant! Right now I'm trying to attach the module, and make it look close to stock I will do some testing soon.
- Seven5555
- Topic Author
I have checked and rechecked the connections...... posting here and asking for help is the very last option because its a very slim chance that help will come. As far as hardware.ini goes, to be honest< I'm not 100% sure what is should read. I installed the 4 n 1 multi module so I modified it to read
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
enable-multimod = A13
If this is wrong, please let know.
Thanks again
I looked up the ELRS and it sounds great but I'm not clear on what protocols it has, is universal ?
- -=Hubi-Dirk=-
www.deviationtx.com/forum/7-development/...dule?start=940#55157
Scroll a little down to the section Devo8, Devo F12E (PCB looks slightly different but MCU and pin are the same) in this post.
You will find this information about the hardware.ini
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
; enable-multimod = A13
- Seven5555
- Topic Author
- Seven5555
- Topic Author
- Home
- General
- General Discussions
- New modules?
