Aileron and rudder reversed?
- Sero
- Topic Author
- RC-addicted
28 Jan 2023 14:09 #78211
by Sero
Aileron and rudder reversed? was created by Sero
I own a Radiomaster TX8 and a Jumper T8SG v2, both running the same firmware.
The Jumper acts normal, I have to reverse both rudder and aileron for DSMX, trim works a intended.
On the Radiomaster, reversing those channel is not needed, but instead the trims are reversed.
Have I missed a setting in Deviationtx, or can this be fixed by simply changing the wiring of those 2 channels on the gimbal-plugs?
28 Jan 2023 16:18 #78212
Replied by hexfet on topic Aileron and rudder reversed?
Sounds to me like those two channels have the gimbal pots backwards. Switching the wiring should work.
I wonder if all TX8's are like that.
- Sero
- Topic Author
- RC-addicted
29 Jan 2023 15:25 #78213
by Sero
Replied by Sero on topic Aileron and rudder reversed?
So, it would work correctly, if I simply swap the plus and ground cable on the hall sensors?
- Sero
- Topic Author
- RC-addicted
29 Jan 2023 15:34 #78214
by Sero
Nope, that has just killed my TX, bummer
29 Jan 2023 22:29 #78215
ouch. I mentioned gimbal pots as the TX8 looks like a T8SG clone with the LCD screen. Might be able to fix with new hall sensors and maybe power regulator(s).
Time to create page: 0.036 seconds
- Home
- General
- General Discussions
- Aileron and rudder reversed?
